Breaker problems
Results 1 to 6 of 6
Breaker problems
    Mar 2010
    Default Breaker problems
    My breaker trips every time I start the boat. The boat will run after started but every time shutdown I have to raise the doghouse to start again. Do they go out very often? What are possible reason to make the breaker trip.
    1995 Carrera, 454 stock, one wire alternator, 180 hours on engine
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Did it just start doing this?
    Have you changed anything in the wiring latlely?
    If not I would just replace it and you should be fine
    Senior Member sleekcraft137's Avatar
    Star, ID
    Quote Originally Posted by Glider View Post
    i had an issue like that, i traced it to a (+12v) wire that was grounding it self to the gauge bracket. Weird stuff, but it rewired the gauge and haven't had a prob since.
    Mar 2010
    It just started this weekend, no new wiring "just before" I converted to a one wire alternator 2 weeks ago and drove 4 tanks of gas with no issues. I'll recheck the wiring because I did put a new alternator bracket just before Memorial day.
    Frozen Tundra, WI
    Your "1 wire" from the alternator is going to the positive on the battery and not thru the breaker right?
    Mar 2010
    I'm not sure about the routing of the one wire. I didn't run a new one straight to the battery when I installed it. Just hooked it up to the big wire that was already there and taped the small ones, per the guy at the alternator shop where I bought it.
