Correct Spark Plug
Correct Spark Plug
    Coeur d'Alene, Idaho
    Default Correct Spark Plug
    I have an original later 1970'S LS7 BBC with 12 to 1 compression..iron heads, TR with dual quads..The boat has always been run on boost or avgas..the plugs are AR135..That's what was in it when I bought the boat and have replaced with the same thing...I just ordered new AR135 and I'm not sure even if that's the right plug..I think AR135 are for small blocks..sugggestions..thanks..
    Feb 2010
    i think in the early 70's they never produced the LS7 but they put LS7 intakes on some of the 454 engines as performance upgrades. your best bet would be to run a search on the head cast numbers to be sure what plugs to run.
    1977 Charger 17Foot. jacuzzi golden eagle
    402 BBC tunnel ram with dual 660 fuel leaks on the top.
    Senior Member Futs's Avatar
    Orange CA, Big River
    Four different spark plug types have
    been used over the years. From 1965 to
    1970, cast iron heads used 3/4" reach,
    13/16" hex, gasketed plugs. From 1970
    and later heads used 1/2" reach, smaller
    5/8" hex, tapered seat sparkplugs. Early
    aluminum heads used 13/16" hex, gasketed
    plugs, 3/4" reach. “Bowtie” aluminum
    symmetrical port, race heads require a 5/8" hex, .708" reach, tapered seat plug.
    http://www.zex.com/Products/SparkPlugs/app.asp
    Thanks futs..
