olds to chevy
Results 1 to 9 of 9
olds to chevy
    Senior Member 71kona's Avatar
    Default olds to chevy
    will the pto off of an olds fit a chevy? or is this a straight stupid question?
    this boat will be the death of me
    corona calif
    Default Pto
    The only items you can use is the driveline and alternator all the rest will be sold with the Oldsmoobile, Maybe the carb if it's a 750 holley or larger.
    Default Ah....No
    That would be a NO. The flywheel bolt pattern is different......Ray
    LOUD BOATS SAVE LIVES
    Senior Member TahitiRat's Avatar
    Fort Worth Texas
    When I swapped mine I almost bought a new pto then I found out that all I need was the pto flange that bolts to the ringgear. looks like this
    if you have a ring on your ringgear that looks like that you can just get the flange
    "Mad" Member Jet Mad's Avatar
    Cape Town, South Africa
    Traitor
    No it won't work, the flange setup will work.
    Wikus
    Default Flange
    It depends on what you have now. If your driveline bolted directly to the crank, the flange won't help you. If your old set up bolted to a flange, (doubtful), then the Chevy drive flange will solve your problem...... The type that bolts to 4 of the 6 flywheel bolts do not have 4 symmetrical holes to bolt to the drive flange. It depends on what you had before......Ray
    PS What ever you wind up using, make sure the spline doesn't bottom out on the shaft. It WILL wipe out the thrust bearing in the motor..........
    ok well lets make this easy, whos got a water outlet and a pto they want to sell me? cheap cheap cheap please! it is the final 2 pieces to get that olds paper wait out for good!
    also, are the h bars universal to the pto flange? or do i need one of those also?
    Wet
    Wet is offline
    East Hampton, CT
    H bars will be fine.
