Newbe to jet boats have some questions
Results 1 to 14 of 20
    Jun 2010
    Default Newbe to jet boats have some questions
    We just got a 73 Kona jet boat all their but a mess. jet drive was disconnected from motor 454 know for the questions.
    1) is there a way to tell if jet drive is good other then looking for waer signs or broken ? as it spins freely and all looks good
    2) previous owner ran hoses from jet pump for water intake up to drivers seat to control water flow witch other tehn changing the hoses to high pressure looks good, but the question is can you run the motor if drive is not engaged or will it not get water flow? if this is the case do you need to run a seperate pump to push water ?
    Thanks for the help as have been looking around here and like it just not sure how may are in my area Phila, pa
    Senior Member Amango's Avatar
    Sep 2009
    Well i will give you some info from what i have learned over the years of jet boating.
    ? 1) inspect the impeller thru the hand hole cover and intake on bottom of boat. Thru the hand hole cover grab the impeller shaft and try to move it up and down if you can you will need to pull the bowl and install new bowl bushings and repair the impeller shaft if it's worn. at that point you will want to make sure the impeller wear wring is OK by pulling the impeller and inspecting.
    ? 2) you can run your engine out of water by hoking up your garden hose to the line coming off your pump that go's to the engine. You want the pump disconnected so you don't case premature wear. so drive line disconnected is a good thing for running out of water. If you tried to run the boat in the water with the drive line disconnected it would not supply water and you would over heat your engine.
    GOOD LUCK and post some pic's!!!
    Senior Member jet460's Avatar
    Mar 2010
    Modesto, Ca.
    Hook everything up and put it in the water. Good starting point unless you have a whole in the hull or something.
    Can always start it up on the trailer at the launch if you just want to be checkin' stuff.
    Me and a friend are well into a 73 Kona project right now, and we would love to see pics of yours.
    Jun 2010
    Default picture when first looked at it
    Jun 2010
    Thanks for all you help. next question is when the jet is hooked up and boat is in water, if you are not moving will water ( jet not engaged) still flow through the engine if not is their some kind of setup to pump water through engine when not moving. ( how long can you idle the motor if not moving and still get water flow through engine). Thanks
    Jun 2010
    Jun 2010
    Jun 2010
    Default interior
    here is pic of interior and if look close next to driver seat and diverter control are the valves previous owner installed to control water flow and to build up temp to engine, one cotrols flow into motor another controls flow out and then there is a bypase valve.
    its just another day DK_Hallet's Avatar
    El Cajon CA
    Quote Originally Posted by Kona73 View Post
    Hey Ive looked at your pics . I hope I got your questions right. Ill try and list them then answer them.
    1. does the motor get water when you are idling when the boat is in water ? Yes it does. Your motor is hooked up directly to the Pump with that the short Drivelive ( which is that piece with the U joints ) . If the motor is turning , and that jet is sitting in water it is always turning and pumping water no matter if your idling or running full throttle.
    2. How long can you idle ? As long as the boats in the water. indefinatley unless your pump stops working
    Hope that helped
    Something Wicked This Way Comes
    Jun 2010
    DK_ Hallet, yes that was what we were looking for was abit nervious to put in water and not have any water flow as have couple friends with V-Drives and they have water pumps. put alot of work into her already as motor had a miss to it and a tapping and some milky oil when bought it but under water flow oil stay same so took shot that problems were from sitting for 8 years, so after a tune up oil change and replacing some of the hoses and flushing out both gas tanks and a valve adjustment shes running fine just getting ready to put her in the water and didn't want to screw any thing up . thanks
    Nov 2009
    Langley, B.C. Canada
    remeber the jet is always turnign there is no disconnect as far as i can see. rev is done by directing the constant water flow forward and backwards to get neutral. dont be sticking fingers where they dont belong thinking your in neutral
    looks like a good start, for running out of the water i use a stand i built for a fire hose at work. but with a four point mounted motor i would look at one of those jetaways i heard they disconnect the drive line it seems like a neat little setup
    Jun 2010
    berkeley calls for 90 wait oil in drive what does everyone else use as cannot find it .
    Senior Member TahitiRat's Avatar
    Fort Worth Texas
    gear oil is what I use
    Default Plugs
    There are two 1/8th NPT plugs on the bowl, at about 10 and 2 o'clock . Pull BOTH plugs to allow air to escape while filling the other side. 90wt is OK, light grease is also OK. There are also pumps that use just water to lube the rear bushing, and if that is your case, be careful running out of water for any length of time........Also.......If you highway tow to the water, there is a good chance of debris getting in the pump from the road. Back the boat into the water enough to clean that out before firing dry on the ramp.......I always bark the engine on the ramp before launching, just to be sure it's going to start......5 seconds or so......Ray
    LOUD BOATS SAVE LIVES
