electric fuel pump help
Results 1 to 13 of 13
    May 2010
    Default electric fuel pump help
    i want to go from an mechanical fuel pump to a electric fuel pump, i got two tanks, each line goes to a fuel filter then one line out to the mechanical pump then to the carb.should i bypass the mechanical with the electric or put it befor the fuel filter???
    Senior Member UNASHAMED's Avatar
    Sep 2008
    Tucson, Az
    basically bypass it, run it after the filters
    "Don't make me get my penguin"
    Kingman/Golden Vly, Az
    IMHO...you would be better off sticking to the mech fuel pump...elect pumps are pushers & unless its mounted back by the tanks, a mech is a much better choice...you can get them in alot of different gph's & they work just fine! ...even with T/R's
    FastRat
    San Diego, CA
    mount it after the fuel filter, it will work great. I have -08 lines from my tanks to the fuel valve, then -08 from the valve to the filter and then -08 to the pump and then -08 to the 4 port regulator and then 4 -06's to the carbs. Works great never had a problem.
    Get a good electric fuel pump and don't worry about it. I use the street strip aeromotive pump in my cruiser with 700hp without problems.
    Boat 405.
    May 2010
    cool thanks guys.....i think i have a fuel starvation problem,when i run full throttle for about 30 seconds i drop rpm's like its not getting enough fuel...when i back off for a little bit then hit it, the r's jump back up
    Glendale Arizona
    Quote Originally Posted by ridinfool View Post
    I chased my tail on a problem with identical symptoms. It wasn't the fuel pump.
    Do you have a fuel pressure gauge on it? If so have someone watch it when you're having the problem. If the pressure doesn't drop see below info.
    My problem was a $8.00 repair. Jet extensions on the secondary metering block fixed it. It wasn't until I changed just about everything else that I found the real problem. What happens is the fuel will wash to the back of the bowl (the jets are in the front) and it will effectively run out of gas. When you get back off the throttle, the fuel bowl will refill and stabilize level and run o.k. until you stab the throttle and hold it again.
    The extensions move the jets towards the back of the bowl by about 1" or so and it's enough to make the difference.
    It's possible that this isn't your problem, however before buying a $200 fuel pump and everything it takes to swap it over, I'd try the cheap fix first.
    http://www.summitracing.com/parts/HLY-122-5000/
    Cas
    Cas is offline
    Angry American Cas's Avatar
    ditto that! there are many causes of the symptoms you're describing. I had the same thing happening on a boat a few years ago and it turned out to be plugged screens in the tank on the bottom of the pick-ups.
    Here are a few other reasons I've read about or seen over the years
    bad check valve on the tank
    plugged vents
    crimped fuel line
    collapsed fuel line
    plugged filter
    plugged filter in the carb at the inlet
    the issue Squirtcha mentioned
    lots of little and inexpensive things to check first. If you're going with a Holley electric, buy 2 so you have a spare to carry with you
    B1 Racing cs19's Avatar
    Ive switched all my stuff so it pumps the fuel through the filters, will never go back.
    On electric fuel pumps you must run a relay, when a pump loses only a little voltage the efficency of the pump goes way way down. They are designed to work with full voltage only. Ive had fuel delivery issues from no relays. If your making any kind of HP and there is a demand for fuel that is something to look at.
    Woodstock, IL.
    What's the best type of relay? when I installed my blue holley electric pump (gen-5 ,no mech pad) I temporaraly used a 30 amp KC headlamp relay and used both outputs. One 10G in then two 12g double wired to a single connector at the pump. It has worked well for years but It is one of those little "I want to get it right items".
    I'm also pulling through the filter and bypass back into it to help cool the pump a tad. Some day I'll run a return line.... maybe.
    The government's monetary role is to maintain the integrity of the monetary unit, not participate in fraud
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Your floats also may not be properly adjusted. I had this problem back with my 660's when they where inline. Properly adjusted the float level and probelm solved!
    San Clemente, Ca
    Quote Originally Posted by Carlson-jet View Post
    I used a standard automotive relay from radio shack, 12V30amp. Have 4 of them in the boat. No problems at all.
    http://www.radioshack.com/product/in...ductId=2062477#
    Glendale Arizona
    Also an excellent suggestion. And that one's free!
    Orlando.FL
    If you go to a fuel return system that problem would be solved. Same principal as fuel injection system. Best explained in Century performance web site.
