460 Cams
Results 1 to 14 of 26
460 Cams
    Salem,Or
    Default 460 Cams
    What cams are you guys running in your 460???
    southwindsforsure justsquirtin's Avatar
    Jul 2009
    rio linda calif
    comp cam #34-336-4
    cam specs intake exhaust
    adv dura 292 292
    dur @ .050 244 244
    valve lift .560 .560
    lobe separation 110.0
    460/alum heads/stealth intake/850 demon/msd ign/75-80 mph
    berk ss-a/ride plate/stuffer/hydraulic diverter/ss loader
    hell of a hole shot=18ft southwind
    058 is offline
    Comp Cams, grind number: 294-3/282-2 S14+4. Intake: .595" Exhaust: .561 [email protected] .050" in. 248 ex 236- 114 L/C
    Maple Ridge B.C. Canada
    I run comp ex -274-h. steath ,ot headers,850 hp, 9.5 :1.
    so far so good,great idle ,turns 5000 wot don't know what impeller
    if I did it again, I would listen to the more experanced guys on here & go roller!!!! I learned the hard(expencive) way research it in the dyno room!!
    Jul 2009
    rio linda calif
    im running rollers on mine
    non-rollers are vastly becoming obsolete, modern oil's won't support the flat tappet cams, especially on break-in. The high dollar racing oils have the zinc required, or the zinc dditive can be added to each oil change/break-in. Hydrolic roller = a happy engine, hydrolic flat-tappet = crapshoot
    More info needed on boat and intended usage. I raced the 429-460 motor in three boats and one play cruiser. The guys here are right about trying to run a std cam, crap shoot with todays oils and technology for grinding cams at the right lifter ride angle for a long life is not good. FWIW I will not run a HYDRAULIC roller to save my life! The last 460 motor I put in a boat was a smaller grind with short duration and iron heads. 18 ft Southwind with a stock berkeley A impellar, no ride plate or shoe and ran 82 mph. I did however move the intake back 3 inches and made the motor into an adjustable rocker set-up useing chevy rockers. M
    Senior Member nosfomoco's Avatar
    Dec 2009
    Sac, Ca
    Roller is the only way to go! I ran Comp Cam part #(Grind#300A-R10)
    .663 lift 262 Dur @ .050 110 Lobe sep.
    Ran it on a .080 460 and spun an Aggressor B Mag Bronze to 6000rpms. It would still turn around and pull a tube or a Wake board!
    1978 Eliminator Sport Cruiser 20.5ft BBF 460!
    Senior Member Futs's Avatar
    Orange CA, Big River
    Quote Originally Posted by rogerroost View Post
    flat tappet, 9.5:1 comp and 850 hp as in carb right? cuz there aint no way that thing is making 850 horsepower...lol
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    Quote Originally Posted by nosfomoco View Post
    what heads and comp ratio?
    Member aj06bolt12r's Avatar
    Feb 2010
    Middle Tennessee
    Default cam, build specs
    30 over 460, 9.5 comp, ported doves with oversize stainless valves by high flow dynamics, cam is custom grind from cam research, hyd flat tappet, .564 intake .588 exhaust 238 in 244 ex duration at 50. 110 lsa with 4deg advance. Port p sonic intake with 1050 dominator, bassett headers. Only had the boat on the water 6 times but so far so good, plenty of power, sounds awesome and perfectly reliable. I must admit I did wipe one lobe on the first cam I installed, it was a similar grind from Scotty, I have no explanation as to what happened to it. I know I did everything correct with the install and break in but it didn't last 30 min. I'm not saying Scotty did anything wrong or that the parts were bad, but I now highly recommend cam research and their cam break in service, money well spent for peace of mind.
    Dec 2009
    Sac, Ca
    Quote Originally Posted by 78CoLeBBF View Post
    C9VE heads with 2.19/1.76 valves ported, it was pretty close to 11:1 comp
    your right Futs ,that should have read 850 dp HP would be nice though
