What size is that hole?
Results 1 to 2 of 2
    Wet
    Wet is offline
    East Hampton, CT
    Default What size is that hole?
    American Turbine transom adapter has a smaller hole. It was threaded at one point, but the aluminum wore out and don't trust a pipe plug. Would a 5/8" expandable rubber plug work? I can always dremel the hole to a 1" if needed.
    Shell Knob, MO
    Just tap it to the next size bigger pipe thread. have done several that way.
    Or the hardware store will have a plug for a thermos bottle that will work just like a boat drain plug.
