Panther to Berkley Conversion
Results 1 to 6 of 6
    its just another day DK_Hallet's Avatar
    El Cajon CA
    Default Panther to Berkley Conversion
    I want to toss out my Panther Jet and move into the 21'st century with a Berk/AT/ Dominator Pump. Can anyone recomend a good place in So Cal that will do the Transom work for this ? Thanks Chris
    Something Wicked This Way Comes
    Texas
    Its been about 6 years or so since i did this same deal, and i'm pretty sure that the hole from the Panther pump is smaller then you'll need for the Berk. You just need to cut out the Panther stuff as close as you can to the pump (smallest hole possible) then get a good "Jet" guy to set your intake, then you'll just have to trim up your transom for the Berk. You will need all new pump, intake, loader, transom plates and cables. Its not near as big of a job as you might think, one long weekend can get it done.
    Nice!
    Member propless dancer's Avatar
    norco, CA
    GS marine did a great job on my Panther to berkley swap.
    "BOUGHT NOT BUILT" 2FORCEFULL's Avatar
    what was the gain..???
    Ladera Ranch
    My bro just finished his conversion this weekend(berk intake set). The panther doesnt extend as far into the boat, but I do believe the insert box for the panther is wider than the berk , which requires some glass work to the floor & transom.
    Edit- Performance (all other things left alone) should be much improved with lots of upside. If you want speed, find an intake with a bolt on shoe.
    Panther conversion: Id avoid it. You could source a complete pump with diverter for under a thousand bux (used)and do the glass work yourself, saving a boatload compared to the conversion.
    Done several of these , always worth the effort !
