normal oil temp after a pass
Results 1 to 14 of 21
    Atlanta TX
    Default normal oil temp after a pass
    What is the normal oil temperature range after a pass ? I grouted my block this winter & now oil pressure drops after a couple passes . Let it cool off the pressure comes back.
    I have seen 220 on my gen V block, idle pressure drops a little at idle, but remains steady under power.
    Senior Member 1320h2o's Avatar
    Sparks nv.
    Quote Originally Posted by cpjet View Post
    Lets see some pics of the new motor Rick!!!
    Senior Member Futs's Avatar
    Orange CA, Big River
    My oil temp gets to about 220-230 after a hard pass. Oil presure drops about 5 psi after but it cools back down to 180-190 in no time.
    Atlanta TX
    I plumbed a temporary oil temp gauge into my oil pan . Made a pass in front of the ramp , shut it down idled onto trailer , pulled up ramp & gauge read 240*. Oil pressure went from 70 at warm idle to 40-50lbs at idle after the pass. Reckon the oil is heating up enuff to cause the drop in oil pressure since the pressure goes back up when it cools ?
    They don't call you two mile Tim for nothing
    10 qrt pan, with what type of oil ?
    Our does about the same as yours and we run an oil cooler and most of the time try to run the oil around 190* and then on hard back to back passes it gets 215-225 depending on the number of passes and length.
    S CP
    same things happening to the twin turbo 496 we 1/2 filled. gotta find him a oil cooler, its not crazy high but i like oil around 180-200* to start
    S CP
    Yes, that is with a 10 quart pan and synthetic 10/30 oil. If i just make a few 1/4 mile blastd my oil stays around 190ish, its those long 1/2 mile pulls that gets it hot.
    Atlanta TX
    Got any leads on a budget priced oil cooler ?
    Norco
    I have done a 3 mile pull above 5200 RPMs with a 1/2 mile blast at 5600.
    The water sizzled on my remote oil filter. I made a pass not quite that hard and saw temps (with heat gun) of 215. I am gonna put on a oil temp gauge next season.
    i'm back!! 1QuickCP's Avatar
    Montana
    ah, 230-250 no biggie. Like to see it over 212 at least to boil off any water in there from condensation and such. consistant 220+ is not a problem.
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    Quote Originally Posted by danhercules View Post
    you prob dont wanna see what it reads
    sorry man, i'm lookin for 1 for him now myself. he's gettin a bad attitude about the deal cuz he thinks it should hold a constant hot oil pressure which is stupid i keep telling him, but he's twice my age and dont listen i've told him time and again its the 1/2 fill that's doin it , to get used to it and quit bitchin
    Atlanta TX
    I know that the block being 1/2 filled is logical , but it still makes me squirm too. I'm gonna try plumbing with bigger water lines in & out 1st & then if I have to I'll go with an oil cooler.
