1.7 rockers on an olds
Results 1 to 3 of 3
    Default 1.7 rockers on an olds
    i have a pretty decent 455 and am still running stock rockers and a 280 magnum cam i know the stockers are 1.6 but has anybody used a 1.7 on an olds? i have found a set of frpp 1.7 pedistal mount full rollers cheap! will i run into a piston clearance issue with the .030 extra lift? the heads have not been milled much just enough to make em flat thanks for the input!
    oldsmopile equipped
    Lake Lansing MI.
    they should work just fine, its not the lift that will tag a piston, its duration. by the time you get full lift your piston is way down the bore. who is frpp? watch out for chinese garbage.
    Ford Racing Performance Parts
