stainless tubing bender
Results 1 to 13 of 13
    Douglas, MA
    Default stainless tubing bender
    going to be bending some 1/2 inch stainless and already broke 2 benders from harbor freight (in their defense...they weren't made for stainless)
    any recommendations?
    I was looking at this one...
    http://www.amazon.com/Ridgid-36132-B...bxgy_hi_text_b
    Senior Member HKROB's Avatar
    I have that same bender it works great well worth the $$$. I have bent afew thousand feet of tube with mine and its still work great.
    the one i used for mine is a parker bender. i got it for 50 bucks on ebay. it works great, the only other one i have seen that is probably the best, is the swagelok bender but it is pricey.
    Anaheim/BHC- the Shack
    I have both Parker and Rigid. Both work well for most jobs.
    Douglas, MA
    Quote Originally Posted by HKROB View Post
    any trouble with kinking or flatening?
    I am bending Stainless Steel 304L Welded Annealed Tubing 1/2" OD x .43" ID x .035" Wall
    Douglas, MA
    Quote Originally Posted by sandeggo View Post
    trying to get a swagelok on ebay, but I think its going to go too high.
    Douglas, MA
    this is probably a bad idea...huh?
    http://cgi.ebay.com/Manual-Tube-Bend...item588800b0fc
    yeah the swageloks go for some serious coin. if the parker, rigid,or swagelok benders, kink or flatten the tubing, you are definately doing something wrong. if you already got the tubing, then dont worry about it, but i would try to get seamless tubing.
    i would only use these 3 benders that i listed
    "Mad" Member Jet Mad's Avatar
    Cape Town, South Africa
    I use the one shown in the pic, use seamless tubing and when doing copper aneal it first.
Name:	Heavy-duty-15 -22mm-pipe-bender-016145S.jpg
    not sure what the shipping would be or how soon you need it, but I'd let you borrow mine.
    Douglas, MA
    to MA, probably as much as buying one
    I do appreciate the offer though! If the ebay swagelock doesn't happen, I am going to order the Rigid I think.
    probably right on the shipping. good luck.
