Tryin to figure out my comp ratio
    Senior Member Swain's Avatar
    Aug 2009
    Default Tryin to figure out my comp ratio
    Piston, Forged, Dome, 4.280 in. Bore, 5/64 in., 5/64 in., 3/16 in. Ring, Chevy, Big Block
    Heads are 990, 2.19 / 1.88 valves 118 cc chamber and 318 cc intake port
    The motor is a 454 4 bolt main
    Stock length rods.
    Crank is 4.00" stroke forged 1053 LS6
    Cam Isky z55 254 duration, 590 lift solid flat tappet
    Jason
    Senior Member Futs's Avatar
    Orange CA, Big River
    what are the cc's on the head chambers,how far is the piston in the hole and what is the head gasket thickness and bore size? What size dome on the pistons?
    Senior Member UNASHAMED's Avatar
    Sep 2008
    Tucson, Az
    Is your block zero deck or are the pistons in the holes and need combustion chamber numbers
    "Don't make me get my penguin"
    Aug 2009
    2.19 / 1.88 valves 118 cc chamber and 318 cc intake port 990 HEADS SORRY
    Deck i think is stock height
    Compression Distance (in)
    1.645 in.Dome Height (in)
    0.221 in.Piston Head Volume (cc)
    -29.40cc
    Normal felpro gasket.
