My First Engine Build
Results 1 to 1 of 1
    Senior Member Cobra 02's Avatar
    Montclair
    Default My First Engine Build
    497 BBC Eagle Crank & Rods, SRP pistons, JE Rings, Clevite Main & Rod Bearings, Edlebrock Victor Jr intake, 850 Mighty Demon Carb, Solid Roller Lifters, S/S Roller Rockers, Comp Extreme Marine Roller Cam, AFR 305 Heads, Milidon 10 Quart Pan.
    4.3135 Bore, 4.250 Stroke, 18 cc pistons, 121cc head chamber, Should be 10-1 comp.
    Clearances Main & Rods .0024, Piston to Block .007
    Sure hope this mother f**ker works
    Question:
    What oil & spark plugs should I use.
Name:	497 Engine build 002.jpg
ID:	77389   Click image for larger version.
Name:	497 Engine build 007.jpg
ID:	77390   Click image for larger version.
Name:	497 Engine build 017.jpg
ID:	77391   Click image for larger version.
Name:	497 Engine build 032.jpg
