Exhaust advice
Results 1 to 7 of 7
Exhaust advice
    Member Katanna's Avatar
    Jun 2010
    Howell Mi.
    Default Exhaust advice
    Just purchased my first jet boat. 78 Python with a 460 ford. It has Bassett over the transom headers. Are these going to be a problem if I have to idle down the river? Should I consider going back to a log type exhaust?
    Thanks,
    Steve
    no need 2 fake it. 84Condor's Avatar
    Yuma, Arizona, United States
    what problem would you have idling?
    "i'm into snatchin' kisses... and vice-versa!" haha
    Nov 2008
    Fuquay-Varina, NC
    Quote Originally Posted by 84Condor View Post
    I have the same set up and my boat idles just fine, you just have to either give it a little stab of gas once in a while to send some water through the headers to keep them from blueing, or run a slightly higher RPM and control your speed with the gate. Mine is set up to have the steam start at around 2k RPM.
    Ideling around in a jet boat is no fun though, as they dont steer well at slow speeds compared to a pro driven boat.
    '77 Caribbean
    Menominee, mi UP
    Aug 2009
    Menominee, mi
    you talking about noise?
    Jun 2010
    Howell Mi.
    Noise does not concern me, it is the issue with the water flow. How often do I have to stab the gas to keep them cool? I dont want to loose my passengers
    Senior Member lbhsbz's Avatar
    Long Beach
    That's the thing with rivers...they have a current. shut it off and float downriver.
    Nov 2008
    Fuquay-Varina, NC
    Quote Originally Posted by Katanna View Post
    Are you worried about the headers getting hot and burning the pasengers? Even with the steam coming out of them I would certainly advise everyone on board to keep their hands away, as they are hot even then. If I have to idle for a while (no wake zones etc) I give it a little jab every 2-3 minutes, or like I said just pull the shifter back towards reverse a bit and use more throttle to keep the water in the headers, but your speed slow. Slow speed handling in a jet boat takes a little getting used to...
    Or you could always just put the logs back on, it might be a better option if you're going to have a lot of guests along that might be tempted to grab the big shiney exhaust header
    '77 Caribbean
