Cam Bearings and new Cam...
Results 1 to 14 of 19
    Mar 2010
    Avondale, AZ
    Default Cam Bearings and new Cam...
    Im in a slight debate with myself on throwing in a mild cam and having to replace the cam bearings.
    I have a '90 20.5 Carrerra with a pretty much Stock Hardin Marine 454. I just put an Edelbrock RPM-Air Gap intake on it, and was thinking of adding the Edelbrock Performer RPM Cam Part # 7162 with an Edelbrock Spring Kit Part #5795 to go with the Holley 750 NON-DP. The engine has 390 hours on it. No issues with the motor, just want a little more out of the cam. Runs 4750rpm right now. Will I need to replace the cam bearings, or should I be ok just putting the new cam in?
    Heres the Cam specs:
    #7162
    ENGINE: CHEVY 396-427-454 V8
    RPM RANGE: 1500-6500
    Duration at 0.006" Lift: Intake: 300° Exhaust: 306° Duration at 0.050" Lift: Intake: 240° Exhaust: 246° Lift at Cam: Intake: 0.330" Exhaust: 0.337" Lift at Valve: Intake: 0.560" Exhaust: 0.573" Timing at 0.050" lift: Open Close Intake: 10° BTDC 50° ABDC Exhaust: 59° BBDC 9° ATDC Centerlines: Lobe Separation - 112° Intake Centerline - 110°
    Lake Havasu az.
    Any particular reason you think it might be necessary to replace cam bearings?
    Sheriff Joe Arpaio
    Mar 2010
    Avondale, AZ
    Quote Originally Posted by Sold honda.bought hondo View Post
    Nope, just want to check with some of you who have more exp dealing with this to make sure, thats all. I didnt know if I needed to, or if it would be ok do just drop a cam in it and change the valve springs. I havent really found a Comp Cam that is comparable to the Edelbrock Performer RPM, so anyone who has any recommendations for this size of boat and a good mild performing cam, Im open to suggestions.
    Senior Member CK7684's Avatar
    Minnesota
    My Bullet cam is very close to the Edelbrock Perf RPM roller cam (which is larger than their flat tappet RPM cam) and I really like mine. Mine has tighter lobe sep tho...
    Why not step up to a roller while yr at it?
    Cam bearings shouldnt be a big deal to replace if need be...
    Mar 2010
    Avondale, AZ
    The thought did cross my mind, but thats a few more shells than what Im looking to drop into it. I figured a decent mild cam to add a little more wow factor and I would be happy, then I would leave it as it sits and quit trying to add more. The cam I figured would be the final icing on the cake in my case. And for a couple shells I could get the cam kit w/ lifters and the spring kit and call it a night.
    Nov 2009
    IMO you should be very carefull piecemeeling your engine together! Atleast do yourself and family and big dog a favor and wait till after summer. you have a nice ride. USE IT! That particular cam isn't gonna change anything like a night and day difference anyhow. Besides to do it RIGHT you need heads and the springs with a new cam. But it looks like your already ADDICTED! so have at it. I'm sure i'll see you again sometime!
    Mar 2010
    Avondale, AZ
    Thx PS...
    Not really looking for a night day difference, just a little more pep to carry the top end. I added the RPM-Air Gap and gained 250rpm, if I added this cam, which according to Edelbrock is matched for what I have, RPM-Air Gap and Holley 750, and gained some pep and a few more RPM's, I'd be completely satisfied.
    Nov 2009
    Quote Originally Posted by headshothills View Post
    Thx PS...
    Sorry to burst your bubble man! Not to many of us are COMPLETELY satisfied EVER! lol But hey the first hit is ALWAYS the BEST. PS maybe you should play with the pump a bit first. That way you don't have to worry about breaking on the water! Just a thought. My neighbor wiped a cam on a brand new Stock 454 that weekend. Wanna take a wild guess who made it? or should I say who's name is on it?
    Senior Member Futs's Avatar
    Orange CA, Big River
    I would leave it alone and enjoy it. Whos to say after the cam swap your pushrods would be the same length and then your geometry will be off, who knows what the piston to valve clearnce will be(without pulling a head to check it) and if you insist on doing the swap, might as well pull both heads,get the right springs for the cam spec and make it a roller. With todays oils, it not worth it to even mess with flat tappet crap anymore. Atleast with a roller, you will feel the pep in it when you switch it out with a nice one.....Its just not that easy to just swap it out in my opinion. Next thing ya know its the middle of summer and you done blowed her up and your stuck doing a rebuild cuz you thought you needed a "bigger cam" !
    Like fut's said, your not gonna notice a real difference with that cam. Also as mentioned, the oils will waist the new non-roller cams, in a heartbeat. You may get lucky to have one survive the break-in, but chances are it will go flat in the near future.
    Mar 2010
    Avondale, AZ
    I know I know, we are men, so satisfaction always changes once we get comfortable something, like we always want to push the limits, I understand that. As far as the pump, it was completely rebuilt 2 months ago by Dan at Jett Performance here in Phx, did an awesome job. Had to replace the bowl, shaft, and impellor...Yah, dont even ask, previous owner, needless to say, $1400 later, I have piece of mind with the pump.
    As far as you cam goes and who made it, Just for the sake of argument, Im gonna say "YOU"...LOL
    Senior Member cave's Avatar
    Mesa, AZ
    Yep, I'd listen to these guys. Have fun this summer then when your ready tear her down Pull the heads, get new bearings, check everything out then if it works out test and tune in the fall or winter! Nothing like adding a part that takes out many other parts.
    Takin it home
    Mar 2010
    Avondale, AZ
    Well, thats the reason for choosing the Edelbrock Cam, its matched for the stock head, pushrods, clearance/lift, and porting, intake, and carb. Its a drop in. Nothing special or radical, the only requirement is to replace the valve springs, and of course they recommend using their timing chain setup. Ive looked at the roller setup, but keep in mind, im only gonna be 400-450hp max, if that, maybe even under 400hp, I agree with the benifits of a roller setup, but its it really neccessary for something under 450hp?
    As far as the swap, I like to tinker and work on stuff, I have an engine compartment that comes out and the entire front of the motor is open, not to mention that the oil pan bolts are all accessible without any problems.
    Mar 2010
    Avondale, AZ
    HAHA, whats to say the stock one in there now isnt flat...
