Alternator went bad have some ?'s
Results 1 to 9 of 9
    Mar 2010
    Default Alternator went bad have some ?'s
    My alternator went bad. My jet is a 73 wreidt with a 455 olds. The alternator was a marine delco. Ive got an automotive alternator laying around from a 455. Would this be ok or is the spark something to worry about? My motor compartment has a lid on it so its not open. If it is something to worry about does anyone have a marine alternator they want to part with? Thanks, Tate
    Mar 2010
    Avondale, AZ
    Check around and see if anyone around you can rebuilt it. Mine was shot, really really bad, the internals crumbled when they took it apart, and it was still only about 50 bucks to have it rebuilt.
    Glendale Arizona
    Quote Originally Posted by Tater10 View Post
    I'd vote for the real deal marine alternator with that closed engine compartment. I run an automotive type and have for years, but my compartment is open.
    I'd also second the motion to try to get it repaired. It would probably be considerably cheaper than buying new. Actually they're not that difficult to rebuild and you could do it yourself if you're feeling adventurous. Brushes, diode trio, voltage regulator (if internal), and a new bearing. That's pretty much it.
    Mar 2010
    Thanks for the advice. I called a place by me they said prob $60.00 to rebuild. Being a closed engine kind of makes me nervous about using an automotive one.
    Knock on wood, mine has lasted 15 years...... it was reman'ed by a local builder. One thing to prolong the alt, is to run the larger racing pulley, slows it down considerably, as the jetboats run 3k and up in RRRRR's
    Nov 2009
    Langley, B.C. Canada
    i spent hours polishing mine then it did not work took it to the rebuild and they got fixed. dont use a auto unit in a inclosed
    i would NOT run one of those moroso large pulleys i ran one for about a week and i would always have a dead battery by the end of the day i like to just float down river and i would start the engine for short periods of time for corse corection but still i have a brand new g29 battery in it and it would not start the boat by then end of most days just my .02
    Alamogordo NM
    x2 on the closed engine compartment thing, my dads boat cuaght on fire once because of a non marine starter in a closed compartment deal.
    Norco
    Dont know where you are, but there is a shot in Riverside that rebuilds starters and Alts.
    Stay with the marine one.
