Need engine builder that can also pull the engine
Results 1 to 2 of 2
    Senior Member nos1967's Avatar
    Default Need engine builder that can also pull the engine
    Boat is in Gardena, ca. I live in puerto Rico currently and only fly home once a summer to run the boat so I have zero time to pull the engine and take it to a machine shop. Looking for good place that I can have someone drop the boat off at and have them pull it, rebuild it, put it back in.
    The current setup is a marine power 2 bolt 340hp 454 that goes through about 3 quarts of oil a day. Still spins the A impeller 4900rpm so no loss of power, but I want more power and to solve the oil issue. Boat is the ultra splash of the southwind T-deck. Pump is a dominator set way back with shoe and ride plate, diverter and soon a droop and loader. Runs 62-65 currently, would like to see 500-550hp and see what speed that gets me to then if I'm still not happy start doing pump work and maybe a little nitrous.
    Junior Member THROTTLE 64's Avatar
    TORRANCE
    I live in torrance my name is jake i could do whatever you need call me 310 701 4863
