Jetboat pluming...Pressure relief valve?
Results 1 to 3 of 3
    Wetnreckless805 Olds 455
    Mar 2010
    Paso Robles
    Default Jetboat pluming...Pressure relief valve?
    I reinstalled my olds 455 this weekend after total rebuild and started on new pluming...whats the opions out there on pressure relife valve?
    Default Tom...
    Quote Originally Posted by wetnreckless805 View Post
    Go see Tom at Jetboatperformance, he's local to Paso.........BUT, IMHO, you don't need a pressure relief. Jetboats ran for decades without them, mine still do. If the intake and cylinder heads are properly sealed, and the "exit" side of the plumbing is adequate, it should "just work"......I run an Olds with wet logs and no other "dumps" without any "milky"oil issues... The only time I try to regulate the exit(s), is with wet headers and a bunch of overlap in the cam...Then I add a ball valve controlled extra "dump" hose to reduce water to the headers........Ray
    LOUD BOATS SAVE LIVES
    Senior Member 787chuck's Avatar
    MorePark
    x2 i just run the next size up line on the exit side and have never had a problem with pressure
