Water pressure???
Results 1 to 14 of 21
Water pressure???
    Speed is a function of $$ mightylandwalrus's Avatar
    Jun 2010
    Rio Medina, Texas
    Default Water pressure???
    Hello all,
    Quick question. What is the ideal (if there is such a thing) water pressure to run to the block to cool the motor? I've heard a wide variety over the years ranging from 15 to 85 p.s.i. and I was just curious. Hate to blown head gaskets. Thanks to all who respond
    Beer is the answer... but I dont remember the question.
    Mar 2010
    Clarksville, TN
    I don't run a pressure regulater but I think 12 to 15 is the number your lookin for ..
    Jun 2010
    Rio Medina, Texas
    thats what I was figuring... side note - do you cool your headers straight from the pump or do you run the water through the block first then to the headers
    "Mad" Member Jet Mad's Avatar
    Cape Town, South Africa
    Quote Originally Posted by mightylandwalrus View Post
    Tee off on the feed from the pump, before the pressure regulator if you run one, to your regulator Tee or Banderlog valve, then to the headers. Do not run hot water through your Over Transom headers.
    Mar 2010
    Clarksville, TN
    I think Basset or Rewarders web site has the plumbing.. Everybody is differnt on this but the way I do it is run your main line from the pump with a gate valve to the block and I then run 1 line off my water neck(therm houseing) to the dump and the other side to my headers useing the Basset T valve with a ball valve on the dump line to control the water to the headers.. I never have had any problems and run a steady 180* all day
    Jun 2010
    Rio Medina, Texas
    thats the way it is set up on my boat now. Dont really have too much problem with the temp (i run around 150- 175 temp) but I was just concerned with the 35 lbs. of pressure at wide open I was running
    Mar 2010
    Clarksville, TN
    I understand that, but they have been doin this stuff for years so if it aint broke dont fix it ... I know they sell a regulator on ebay if that is something ur lookin for
    Jun 2010
    Rio Medina, Texas
    I hear that .... I already have a regulator on there right now but I dont think it is working very good. I've broken it down and tried to adjust the spring a little but it didnt seem to help any. This has been an on going issue for two years, not really a big issue but wanted to fine tune it.
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    I have used and installed the pressure relief kits from HI Tech Performance on my own boats and other friends and they have always worked great.
    They come pre-set and all you need to do is adjust the gate valve for your desired engine temp and your good to go
    http://www.hi-techperformance.com/Wa...ass%203714.JPG
    Senior Member 4trax's Avatar
    Shawano, Wi.
    Quote Originally Posted by Fonz69 View Post
    Same thing I run & same thing my son runs. Works AWESOME
    I went in and got recircumsized again........I lost 10lbs. & was able to save the lives of 3 children in the burn center.........but it's not my fault they turned out to be dickheads.
    [email protected]
    Wetnreckless805 Olds 455
    Mar 2010
    Paso Robles
    I Just installed a pressure relief valve that dumps over board anything over 15 psi. in my opinion it cant hurt as long as you can maintain temp and flow through the block...run it if you got it!
    Alamogordo NM
    Default 12 psi
    I like to see no more than 12 psi in my block, after blowing a set of intake gaskets (wrong gaskets for aluminum intake), I added a overpressure dump and a fuel pressure guage in the water crossover. I see about 5 psi at idle and 10-12 at wot, no overtemp yet.
    Precision Craft Marine
    Napa, Ca
    We put pressure reliefs on both jets and v-drives. We set ours @15-18psi on the hose bib, and it always comes in @ 12-14 psi on the pump, without a gate valve. This usually will put the engine temp at 150-160. Engines make more power running cool than hotter, they just wear a little faster running cool.
    Check the OEM pressure stats for your engine, every engine has a different PSI at which the cooling system runs.
    Olds like to see 22Psi for example. I found that at altitude engines tend to run a little hotter than at sea level.
    Something to do with the boiling point of fluids. The higher you go the less time it takes to reach boiling point. Just an observation I might be wrong.
    Wikus
