power valves/jet size
Results 1 to 5 of 5
    Aug 2009
    Default power valves/jet size
    ive got 750 d pumpers on a t=ram 532 ford lookin for jet and p valve recomendations please.......... mikey
    Mr SEXCLAMATION
    Upland, CA
    call Dave at Fuel Curve West. 909 920 3779
    Default Original....
    Holley tells us not to exceed 4 sizes, up or down, when changing jets. Find out what jets came in the carbs, and you'll need some water time to establish which direction to go. I would run what came in the carbs until I found a reason not to..... Using a "tattletale" tach, and a GPS, go for a test run.....WRITE DOWN the results in an "engine log"........Change ONE thing, and retest, writing down the results.....Using the recorded info as a guide, either continue on in that direction, (if performance improved), or go back and go the other way...... An EGT data, or light console, will help more than you could ever know. "Split Second" (brand) sells a real cool system for a couple of hundred, but it won't work with the headers wet...... The P/Vs should be rated below normal cruise vacuum by a couple if inches, so you'll also need an accurate vacuum gauge you can see easily from the driver's seat...... Take the time and do your "homework", writing down results, and remember, change ONE THING AT A TIME!!!!.......Ray
    PS there are no recommendations because there are so many variables to consider.... No two engines, or boats are the same. You're going to have to dial yours in...
    LOUD BOATS SAVE LIVES
    Derby, Kansas
    Which 750 dps and what tunnel ram?
    Aug 2009
    WIEAND T=RAM ABOUT 5-6 YEARS OLD 4150 mech secondaries 7-8 years old 71 jets
