troubleshooting ride plates
Results 1 to 11 of 11
    Douglas, MA
    Default troubleshooting ride plates
    I have one of those 6 way ride plate switches...well...only 1 of my plates seems to be moving.
    Where do I start on this?
    Also, what would I have to do to use the up/down switch on my throttle as well?
    Glendale Arizona
    Just to clarify.......... Are you referring to trim tabs, cavitation plates, or tunnel plates? Maybe a picture of the plates, the switch (front and back), and actuator?
    Douglas, MA
    you know...I don't think thats a part of the boat I ever take pics of
    here is the hydraulics to the left
    http://www.flickr.com/photos/menard/...7616396786774/
    I guess they would be trim plates since they look like this
    Glendale Arizona
    Yes look like trim tabs.
    Being in the electronics game for the past 20 years, I find one of the easiest and best ways to troubleshoot problems is to component swap if you're able. Looks like it would be a relatively easy task to swap actuators from one side to the other.
    Swap the actuators. If the same one doesn't work and the other one does, it's the switch or wiring.
    If the one that worked ceases to function and the one that didn't does now, it's the actuator itself.
    Otherwise if too difficult to swap, a test light or Volt ohm meter to test the switch.
    Honestly the switch or wiring/connections are the best probability for failure.
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Honestly the switch or wiring/connections is the best probability for failure.
    Great advice
    Douglas, MA
    I am really unsure how those switches work...how do I start checking it?
    Senior Member Futs's Avatar
    Orange CA, Big River
    1. If trim tabs do nothing . . . no movement . . . no sound from HPU:
    • Inspect for blown 20 amp in-line fuse in helm control’s orange wire.
    • Inspect for disconnected or corroded connections on HPU ground wire,
    orange positive wire from helm control, and quick-disconnect plug.
    2. If HPU runs but trim tabs do not move:
    • Inspect for disconnected or corroded red and green wire connections
    at helm control and quick-disconnect plug.
    • The following test can be used to help isolate malfunction.
    Remove wires from helm control and touch together as follows:
    Operation Reaction
    O range ( + ), blue, red Port trim tab down
    O range ( + ), blue, green Starboard trim tab down
    O range ( + ), blue, red, green Both trim tabs down
    O range ( + ), yellow, red Port trim tab up
    O range ( + ), yellow, green Starboard trim tab up
    O range ( + ), yellow, red, green Both trim tabs up
    If trim tabs function in each of the above combinations, check helm
    control. If during this test trim tabs continue to malfunction, inspect HPU.
    3. If one trim tab operates and the other one does not:
    • Inspect for disconnected or corroded red or green valve wire
    connections at helm control and quick-disconnect plug. (Red wire
    operates port trim tab; green wire operates starboard trim tab).
    • Reverse hydraulic lines at front of HPU to determine if malfunction
    is in HPU or actuator / hydraulic connections. If after reversing lines,
    symptom shifts to other trim tab, malfunction may exist in HPU. If
    symptom remains on the same side, malfunction may exist with the
    actuator/hydraulic connections.
    4. If trim tabs go down but will not retract:
    • Inspect for low voltage of the battery. Check battery for voltage while
    HPU (or another accessory) is running. If voltage is less than 10 volts,
    valves may not open.
    • Inspect for disconnected or corroded connections on helm control,
    This general information is not intended to be complete. Please feel free
    to call Bennett Marine to assist in solving situations not clarified or addressed
    above. Bennett Marine customer service is available to help Monday through
    Friday, 8am to 5pm Eastern time. (954) 427-1400.
    Glendale Arizona
    Gotta love the internet..........
    Nice work Tim. Looks like that answers all the questions.
    Operation Reaction
    Douglas, MA
    yup...this will be a nice weekend project
    Douglas, MA
    I swapped the hydraulic lines on the pump and the opposite tab worked.
    Bad pump?
    Douglas, MA
    Just to help out those in the future via the search function...
    Talked to Bennett who were SUPER helpful and friendly. I will be testing the solenoid next by putting full power to the green wire. If the solenoid clicks, the problem is with the switch or a connection. If it doesn't, I will need a new solenoid.
