Another Diagnosis
Results 1 to 14 of 23
Another Diagnosis
    Default Another Diagnosis
    Hey guys, Got towed for the first time this weekend. I would like to make it the last. Im not much of an engine guy other than some basics, so looking for some advice. This might be a little long but I want to try to give all of the details.
    Just got this boat with a stock 460 ford. Has been running great for 4 trips this year other than some oil coming out of the block at the distributer. My father in law who is a legit mechanic marks the distibutor and block and pulls it to replace the seal. We put it back in at the same marks and fire it up at home. Starts a little rough but I think its just cold.
    Go to the river this weekend, boat fires, but dies several times, idling a little rough, and hiccups out of the carb at idle in the marina. I go out a little and hit it, but something isnt right. Takes twice as long to plane out and im only getting 4000 RPMs rather than the usual 4500. I drive about 3 miles and it hiccups again as were cruising. Doesnt die and runs pretty consistant, but feels like its lagging and still not getting over 4000 RPMS.
    At this point I think timing must be off. I dont have a timing light but have the marks from when we pulled the distributor as a start point, so I advance it slightly. RPMs at idle go from about 400 to 600. Seems to idle a little smoother. We take off and still not planing as quick as normal, but after getting on plane i get the full RPMs so I figure we are close enough for now and I just need to pin down timing when I get home. Head over to a beach, park it for a couple of hours and then it doesnt start again. Checked spark off of 2 different plug wires and get nothing. Then get towed in.
    I am told this is a GM style HEI pro comp distributer. (google doesnt provide many good reviews of the pro comp distributor)
    Was my ignition starting to fail and then just took a shit when I adjusted the timing? There are a couple wires going into it that are connected, but done feel tight, and the wire housing is resting right against the distributor.
    Any suggestions are appreciated.
    Bakersfield
    Quote Originally Posted by Laser23 View Post
    There's your answer ditch that thing and get an MSD ready to run dizzy.
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Well the "legit" mechanic should have stuck a timing light on it when it got set back in for starters.
    The Ford guys here might have some ideas, but look for the simple things first like check all your plug wires and make sure they are clicked in all the way and the firing order on your cap or any wires you took off or if you did not take any off and maybe pulled a wire loose in a boot?
    Make sure the cap it seated all the way and not up higher on any side....
    Those wires coming out of it you mention make sure they did not get pulled loose inside or rubbed bare and going to ground somewhere.
    I think it comes back to the timing thing when you pulled the dizzy
    Beg, borrow, buy or steal a timing light cause your going to need one now
    Frozen Tundra, WI
    Quote Originally Posted by Luckie Stiff View Post
    yep cant beat a MSD
    Senior Member scottietwohoty's Avatar
    La Mirada, CA
    Does it have points? If it does you might have fried the points. Get the electronic conversion and don't look back.
    It's only as good as you make it!!
    It is electronic. I guess I was just wondering if this is common with this distributor, or if I should also look at another cause?
    Bakersfield
    It is common for that dizzy to not work, the fact that you even got it to work at all is a lot more than some folks. Ditch the Pro Crap and pop in an MSD or Mallory unit. You'll be glad you did.
    Another choice would be the DUI M32820 Ford 351C-400M-429-460
    http://www.performancedistributors.com/index.html
    Senior Member jet460's Avatar
    Mar 2010
    Modesto, Ca.
    X2
    MSD box, dist, coil.
    Gap plugs at .050. and run it.
    Misfires will be a thing of the past.
    Denton, TX
    Default First things first
    Main thing I see wrong is your dizzy is in the front of the motor! J/K
    Pick up a timing light! second everytime you pull a dizzy check it with a light!
    If your set on keeping your current dizzy check all the connections. A wire may have come loose somewhere during the seal change.
    Senior Member lbhsbz's Avatar
    Long Beach
    I'll bet he didn't remove the cap when he did this. The distributor turned a bit due to the helical cut gear when he pulled the dist. out, then went back in exactly one tooth off.
    As far as the Procomp haters....I've had better luck with the Procomp stuff than I have with MSD (My Spark Disappeared). If you have no spark at all, it's very possible that you've got a bad distributor. Check all your powers and grounds. I'm assuming this is a Ready to Run distributor with an external coil. If you've got power to the coil + and continuity between the coil - and the distributor, then it's safe to assume that you've got a bad distributor, or a bad coil.
    Redding, CA
    X2
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Ladera Ranch
    Sounds like coil died and distributor could be off a tooth. Make sure coil is wired properly and check for spark again. If no spark still, replace. Yank distributor and verify that it is indexed properly. Set timing with a light.
    El Cajon , Ca
    Check to make sure you did not shear a dist gear roll pin.
