450ish hp gets 3300rpm?
Results 1 to 14 of 19
    lawnmower repair man
    Default 450ish hp gets 3300rpm?
    its A heavier hull 75 18' challenger fresh berk pump, Diverter stuffer with a bronze B. All new boat really. All new guages. Mtr is a mild 454. flat tops its maybe 10 1/2.1 cams like 580ish lift, tunnelram with dual edlebrock 500's. motor is FRESH. msd dist with the msd6 box. Pulls real good out of the hole mid seems to stop at 3300 just as its starting to go.... At first I thought the tach was wrong still kind of do Its no race motor but seems a bit weak to me. lean timing hits the brakes that much?
    cfm
    cfm is offline
    What cyl heads ? A typical 119cc comb chamber with typical 'flat tops' in a 454 = 8:1 compression or so.
    you are prob right. I believe the motor is a 1978. He had some head work done when the motor was rebuilt. maybe just lack of torque. but 3300 rpm?
    Spiral out MikeF's Avatar
    What's your total timing at 3000 rpm?
    Quote Originally Posted by MikeF View Post
    Good question. Let's add to this....
    Is the throttle cable adjusted to allow the carbs to open fully?
    Are the secondaries even opening?
    Are you sure the tach is accurate?
    What speed did you see at 3300rpm and how does that compare to speed before this work was done?
    Good call ,What he said !! Tom
    Newton Ks.
    You have a problem of SOME KIND.
    3300HP on a B is only arround 90HP requirement.
    H.L. Mencken
    Most boats won't even plane off at 3300 rpm's, especially if your running a "B" impeller.
    # 1 check that tach
    # 2 check the fuel pressure and float levels
    #3 total timing and read the plugs.
    Answer these questions, then you will get you will be headed in the right direction.
    Barrett, what are you up to now?
    G H E T T O F O E L I F E
    Drop one of them Grose motors in there and run it It will see more than 3300
    its my old old mtr. its fresh tho. I do not think the tach is right. im thinking timing 36-38 at 3000rpm let er rip. I just went for a ride I didnt have time to help him. I think it sounded like 4300rpm. he put 2 500cfm edle's on a ram. Not sure what the jetting is, think he said feul press at 5. we were getting 3k rpm and adv timing a tiny turn, then he got 3300rpm. He used to have a olds 455 in it, he ran 62 or so with it. To me it seemed at the suposed 3300rpm we were goin 60. does the msd 6a box have cyl type options like the 6al? I tell ya tho it LAUNCHES straight out and gets with it, just seems to stop.
    Quote Originally Posted by notathing View Post
    All above are good places to look but cam timing could be a problem. Launches like a bullet and lays down at 3000 RPM???? What timing gear and chain set did you use and who set it up????????? I have seen a Cloyes with all the different Boxes,Triangles and zeroes mess with a few minds. B cut bronze and a big block "STOCK" should go atleast 4800 rpm
    Monroe, WA
    So how many Rs would the Olds pull?
    I'll say it... Should'a kept it!
    What number heads? If they are open chamber I hope the pistons aren't really flat tops...
    Malcolm
    75 Spectra 18
    77 Spectra 19 project
    It is a cloyes, the motor is a bit more then stock. It worked well in my old 71 sanger would get 61-6200rpm mite have had a hun or so more I didnt try I figured going from vdrive to a jet he'd lose 600-800 rpm.? it starts good. Idles ok needs some playing with for sure. just want to help get the most out of it. He did a great job redoing the whole boat
