Which is betterand stronger?
Results 1 to 2 of 2
    Senior Member LOLYFE's Avatar
    Idaho
    Default Which is betterand stronger?
    I have two different pto set ups for a bbc. One is the Berkeley pac a jet setup which has the driveline and pto drive plate in one, uses four of the crankshaft bolts and two others under it to attach it the crankshaft, and I have a pto drive that bolts to the crank with its six own bolts then four more attach the drive line to it. Whats the better setup? Both are 1330 series joints, this is a budget build type deal, but since I have both just wondering, thanks
    Shell Knob, MO
    If you're using a three point set up for mounts, use the one piece Rockwell. If you're going with a 4 point set up use the two piece Spicer. Not much difference in strength; just length.
    Duane HTP
