Torque specs on bowl bolts????
Results 1 to 6 of 6
    May 2010
    Discovery Bay, CA
    Default Torque specs on bowl bolts????
    any one know the proper torque specs on the Berkeley JC one piece bowl retainers?
    Break Out AnotherThousand
    ................."Drive the seal in with a soft face dead blow hammer
    and a large socket. This seal is notorious for coming out. We recommend
    a small drop of super glue to help hold it in place. Install bowl and
    torque bolts to 50ft. lbs."
    (excerpt from the AT PDF manual)........................ info is here
    http://www.americanturbine.com/downl..._oh_manual.pdf
    May 2010
    Discovery Bay, CA
    Thank you Tom
    May 2010
    Discovery Bay, CA
    Hey Tom Do you recommend any thing on the bolt threads such as anti sieze I found mine a little loose and thats what caused the gasket to blow out also noted some white crust on the bolts
    torque bolts to 50ft. lbs."(excerpt from the AT PDF manual)........................ info is here
    Quote Originally Posted by orange bahner View Post
    A little antiseize can't hurt , looseness on Bowl bolts seems to occur long term as the gaskets would shrink ...
    San Diego, CA
    Antisieze is your friend. All submerged hardware get antisieze. loader bolts, bowl bolts, steering connections, droop bolts.
    Then again all stainless fasteners should have antisieze on it to prevent galling when using stainless on stainless.
    Boat 405.
