Hardline Source?
Results 1 to 9 of 9
Hardline Source?
    Alamogordo NM
    Default Hardline Source?
    lookin to go with hardline for my water lines, but I can only find it at summit/jegs so far. The only line that comes in the sizes (5/8, 1/2) I need is allum. Also the only "terminations" I can find are female AN tube nuts and sleeves.
    So, who is your hardline source?
    Is there such a doohickey to go from hardline to NPT female, or do I have to go with a male AN to male NPT adapter and AN tube nut?
    Morgan Hill
    If it is made on this planet.....These guys will have it.
    http://www.ryanherco.com/
    GT
    LAID IN MEXICO
    santa paula, ca
    Default aircraft spruce
    aircraft spruce used to have good prices on ss hardline. remember, the thick stuff is harder to bend, and the seamed line might split when you flare it. worst thing i ever did was use a thick 1/2 line, hard to flare too.
    Senior Member Futs's Avatar
    Orange CA, Big River
    I have a grip of this stuff in my garage I took out of a boat. Most of it is straight with a few slight bends and it has all the collars and fittings. I would be willing to let it go for dirt cheap.
    Senior Member superdave013's Avatar
    do it in stainless. the alum typ. comes in rolls and looks like poop in boats. Stainless comes in straight sticks. Any place that sells industrial pipe should have it. Ask for seamless, bright, annealed 304 s.s. tube.
    As far as those fittings, Parker and or Swagelok should have them. They will be spendy in stainless though.
    If you can't find the stuff local McMaster Carr will have it all. (but can only ship 6' lengths or so)
    Senior Member 78_Tahiti's Avatar
    North Highlands, CA
    These guys offer lots of alternatives. http://www.classictube.com/products.asp
    Jun 2010
    I have tons of this stuff at work. But I only have 3/8" & 1/2" x .035, .049 and .065 wall if you need some. Its 316L bright anneal which just has more nickel that 304L. PM me if you need some.
    swagelok, ham-lok, etc require no flaring. get the fittings on ebay. i found the tube locally. if you have a parker hannifan store near you they will have it. 1/2" will be right around 5$/ft. i found a cheaper supplier locally and got it for 3.50 ish/ft. use a good industrial hand bender. these guys are who my local supply was. i know it doesnt help you but it might help others.
    http://www.duhig.com/
    Douglas, MA
    http://www.amazon.com/gp/product/B00...ef=oss_product
    a good bender and flaring tool and you too can do this:
