Lets talk temp
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 54
Lets talk temp
    Senior Member Constant840's Avatar
    Yucaipa, Ca
    Default Lets talk temp
    I thought I would beat HJ to the punch and ask everyone what temperature they run and their opinions on them. I am quite frankly, surprised he hasn't started one yet.
    Anyway, In a recent plumbing thread there were some very different opinions.
    So, what temperature do you run? Why?
    mmmm..........i dont think i have a temp gauge...........
    El Cajon, CA.
    I don't think HJ has hit the water yet.
    Too many beers ago to remember what the Miller and the 1st engine in the Mach 1 did on engine temp.
    Here's a clue on the 1st engine in the Mach 1 though...
    little jb weld and some sandpaper, good as new..........
    Senior Member NO BUTT NO PUTT's Avatar
    Santee, CA
    Im not sure my gauge works.
    It will run 100 in the winter and 135 at idle in the channel.
    Senior Member Dogballs's Avatar
    So cal
    I would say these numbers would vary based on the application and HP of the motor. I run the water 110-125 and the oil 180-200. Its a balancing act but I believe getting the oil hot so it does its job is priority #1. I was told cooler temps make more HP
    Senior Member TrollerDave's Avatar
    Chino,CA
    Different setups=different temps.
    I have no bypass, no jet inlet regulator, no t-stat. From jet to block, 2 out the t-stat housing- 1 to headers, 1 straight to dump.
    If I remember right, idles usually at 190* runs about 100*-110*.
    I have to control temp/flow with the ball valve on the inlet of the jet.
    It's not the best way but it works for now.
    Cantard 71hallett's Avatar
    snow bank
    Any of you guys run a t-stat or just a restrictor?
    Senior Member cave's Avatar
    Mesa, AZ
    Mines been running at around 155° but I'm sure that will change when the water heats up.
    Takin it home
    water temp, not ur speed hotrod.............
    Santee, CA
    I have a ball valve at the jet. Thats wide open. Straight to the water pump holes. Out the T stat with no restrictor or t stat. One goes to the bassett valve one dumps out the back.
    My temp never goes over 135 in the summer.
    It stays around 100-110 right now.
    Yucaipa, Ca
    I consistently run 170-80 (water temp) and will climb to 190 while idling after a run.
    Too hot?
    130 seems really cold.
    Mesa, AZ
    I wish
    Takin it home
    Santee, CA
    Am I running it too cool?
    I was told to open the ball valve all the way.
    My old boat ran the same way. 135-140 max.
