blowing hoses
Results 1 to 14 of 19
blowing hoses
    Senior Member Jetboat Jared's Avatar
    Apr 2009
    independence oregon
    Question blowing hoses
    so for the second time i blew the hose coming from the pump to the motor. almost sank the boat both times. i would like to see some pictures of the way you guys are regulating the water imput from your pumps.
    thanks in advance
    High Rock Lake, N.C.
    You using braided hose? The hose blowing out or a fitting coming loose?
    CLASSIC HOTBOATS!
    Apr 2009
    independence oregon
    yes its braided hose and no its not fittings. i need to put a regulator in i know that much but i would like to see some of the diffrent ways you guys are going about this
    I run a hard line from pump to valve then hose.
    Made In The Shade
    Custom Window Tinting
    A barbed fitting should sovle the blow off. A presure relief valve can be used to reduce system pressure too.
    Redding, CA
    Mine is 1/2" pipe (hardline) from pump to the pressure relief, then hard line up to the back seat where it splits to braided. One braided line goes to engine water inlets, other goes to water control at steering wheel, then back to T valve and header.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Santa Clarita
    How exactly is the hose failing??? You shouldn't be going through braided line like that if its a quality product assembled correctly.
    San Diego, CA
    If you are using braided hose you need to use an hose fittings not hose clamps. The braided hose dose not work well with hose clamps.
    Boat 405.
    May 2010
    SoCal
    On this same topic, ive seen some adjustable pressure regulators from Grainger and similar industrial supply, that can handle up to 300 PSI. Will they work? Also, what is the optimal PSI?
    Anaheim Hills
    Agreed. Ditch the pep boys kit.
    I run the blue hose with push on fittings.
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    hard line to ( gonna get crap but i don't care) a ball valve as a regulator , then blue line .. if anything ever goes wrong with the line you can close the ball valve and save your boat !
    [/SIGPIC]
    bfp
    bfp is offline
    Top Fuel Jet bfp's Avatar
    ca.
    you must have the impellor way back to get that much pressure to blow any kind of hose off
    Redding, CA
    Quote Originally Posted by Lucky View Post
    I remember My first beer!!
    Sorry, just had to do it!
    I have a gate valve between every component on my system, I'm a little paranoid about sinking also!
    Our hydro had a braided dump line with a hose clamp at the transom fitting when we bought it. I almost sunk it because of that.
    (I did not look at it first time out)
    Anyone running a hose clamp on a braided line is asking for trouble. (If that is his situation)
    Tommy
    Ladera Ranch
    J
    Quote Originally Posted by My73Tahiti View Post
    Yes those will work. Try a search and you can see which parts are in use by others. If the motor is stock i would shoot for 15 psi max unless it has some mls gaskets in it, then if power requires you can go to 20-23psi.
