Frustrated!!
Results 1 to 14 of 21
Frustrated!!
    Senior Member sleekcraft137's Avatar
    Star, ID
    Default Frustrated!!
    So I get all the problems fixed from my last trip, i replaced the plugs and re timed the motor and changed my carb. I just hooked up the boat to the garden hose and ran it for 2 min or so................i then check the oil !!GREY!!! WTF?? I checked the oil yesterday and it was as clear as fresh oil, today right now its all greyd out and currently draining from the boat. I did a quick compression test and i was about 160 in all cyl.
    I dont get it, i ran it on tues for a few hours and it was fine, i fired it today and its butt monkeyed!
    And the new project begins!
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    did you turn the hose on , then start the boat or start the boat then turn on the hose ??
    [/SIGPIC]
    Senior Member Daddy B's Avatar
    You may have a problem, but you most likely had the garden hose flowing too quickly......or you left the hose running while motor was not running. The hose needs to be flowing slowly, and someone needs to be there to turn it on once the motor is already running and turn it off before you shut down the engine......Don't panic yet drain oil and try again. I hope this helps...everyone has had this prob before. good luck.
    Star, ID
    Quote Originally Posted by Lucky View Post
    hose first.....could it have backed up through the exhaust?
    Star, ID
    Quote Originally Posted by Daddy B View Post
    Drain the oil filter too right??
    Ukiah,Ca
    Quote Originally Posted by sleekcraft137 View Post
    you have logs , it looks like -- you may have a crack , do you also have a oil cooler ? ( hardin type )
    [/SIGPIC]
    Star, ID
    yep !
    Just my LUCK!!!
    You bet.....it will happen with logs or headers
    Oil filter too.......I think you are problably going to be alright. Sometimes it takes two oil changes to get water out.
    New Jersey
    You mean CHANGE the oil filter, right?!!!?!
    Doug
    Star, ID
    Quote Originally Posted by Real McCoy View Post
    Doug
    Absolutly change! Any tips as to getting this out filter off? The logs and the stringer make it REALLY hard to get too
    Senior Member bp298's Avatar
    LHC
    on my cruiser, i always pull the log off that side, then plastic bag around the filter. it's a pita, but it's the only way to get to the thing.
    Star, ID
    i was thinking about that.....can you re use the gasket??
    Dallas, TX
    If you have not stared it again you may want to pull the spark plugs before you turn that motor over again. If there is enough water still in any of the cylinders you can do serious damage by hydro locking it. Pull all the plugs and turn the motor over without the plugs in to clear the cylinders.
