SOO i bought a fresh bone stock 455 today!
Results 1 to 9 of 9
    Default SOO i bought a fresh bone stock 455 today!
    like i said i found a fresh bone stock 455 on cl with a new edelbrock torker intake mallory unilite and pro coil (Witch i have soo cleverly named "Sweet Pea" lol) today to put in the boat for a while and to keep as a spare for when the big motor breaks but what kind of tips would you have for keeping it alive Keep in mind it i know nothing about it i am assuming it to be a basic "stock" rebuild the guy didnt remember if he put restrictors and a hv pump in it so i am assuming no until i am proven diffrent aside from keeping it below 4000 rpm and NO wide open runs any tips on making it last i am putting my boat pan on it and external filter mount with a hv filter will just beeing easy on it be enuff to make it live
    Van
    Van is offline
    Pull a main cap, any one but the first one. Check to see a grooved bearing in the cap. If it's not grooved, buy the right ones and change them, simple & very cheep.
    Quote Originally Posted by Van View Post
    simple yes cheap no lol i just bought bearing for my other one and they were like100 bucks for the mains lol but yeah i will probly pull the rear main toput a good rear seal in
    Lake Havasu az.
    Marine head gaskets (monellos's) and minimum .0025 rod/main clearance.
    Sheriff Joe Arpaio
    Quote Originally Posted by glastornjet73 View Post
    Just curious if this is a Marine motor (clearances) ?
    Member Trever Leach's Avatar
    Jun 2010
    thousand palms, Ca
    just curious. what makes a marine motor a marine motor?
    Senior Member lbhsbz's Avatar
    Long Beach
    Quote Originally Posted by Trever Leach View Post
    When it's bolted into a boat instead of a car..LOL.
    most curious about piston to cylinder clearances in this case, Marine Applications generally require an extra .001"-.003" clearance because of the possible combination of high load operation and cold water to the block. A cold block with hot pistons is what may dictate the need for extra clearance
    Lake Havasu az.
    My 455 came out of a car and i while i must admit to not actually measuring piston/wall clearances it did have stock pistons in it, i swapped in another set of barely used stds back in that had less dish, and the end gaps on std rings i used set up right on spec....
    I am don't think anything more than an extra thou piston to wall is really needed...more important is the marine head gaskets..The mondello's i used have much smaller coolant passages and after a conversation with monedello i was told that 455 olds in a marine application have a tendency to over cool the 4 center cylinders..as it happens...the motor i took out that had automotive gaskets had the skirts destroyed on both sides of the 4 center cylinders..I run v-drive..no t-stat and it might take as mucg as 10 min. at light throttle to get it up to 150 degrees but it will stay above 150 ans less than 180 all day...and while i haven't torn down to inspect i run a comp check every 2 times out and it hasn't changed since break in
    Sheriff Joe Arpaio
