460 ford with holley 750 double pumper bogs down. Fuel pump?
Results 1 to 14 of 20
    Senior Member neattouch648's Avatar
    Nov 2009
    El Paso, TX
    Default 460 ford with holley 750 double pumper bogs down. Fuel pump?
    When i bought my boat it came without a fuel pump. I put a stock fuel pump off of another ford engine on it. I think it came off of a 302 or something like that. The boat runs fine and idle and without load but as soon as there is a load on it (in the water) and you step on it it revs up fine and then boggs down after a couple of seconds, If you return it to idle and then rev it again after a couple of seconds, its back to being perfect. Could this be the Fuel pump not filling the bowls up quickly enough?
    Senior Member harley222's Avatar
    Sep 2009
    sounds like a good place to start.....
    Senior Member zacho!'s Avatar
    tucson, Arizona
    or clogged filter..
    Ck your fuel pressure gauge. You could have some crap in your tank.
    Made In The Shade
    Custom Window Tinting
    May 2010
    are you running 92 pump gas??
    Member TrynPas's Avatar
    Litchfield Park, AZ
    Quote Originally Posted by ridinfool View Post
    is this neccesary with less than 10:1 compression?
    You done got my kentucky ass all confused!!!
    Senior Member 78_Tahiti's Avatar
    North Highlands, CA
    the 92 octane is well worth the 2 or 3 bucks a tank difference in price. Are your tanks aluminum or fiberglass? bee seeing a bunch of the fiberglass ones coming apart lately with the newer gasoline. The methanol softens them up. also the pump you got may be a little week for big block. Remember horsepower is = to gallons per hour of fuel, a little block only needs 2/3 of what a big block uses. I might try putting a hose in a 5 gallon gas can directly to the fuel pump, then go drive it. you will know then if its pump, carb, pickups (in tank) filter, or tank!
    oldsmopile equipped
    Lake Lansing MI.
    Quote Originally Posted by 78_Tahiti View Post
    Are your tanks aluminum or fiberglass? been seeing a bunch of the fiberglass ones coming apart lately with the newer gasoline. The (ETHANOL) softens them up.
    fixed it for ya....
    Nov 2009
    El Paso, TX
    I found a high volume mechanical pump for 30 bucks so i went ahead and ordered it...140gph should be enough right? I did replace the filter and i do run Ethanol free 87 but I will switch to 92 next time I fill up. Keep your fingers crossed for me
    Sep 2008
    Yuma, Az
    Quote Originally Posted by neattouch648 View Post
    I hope you either have or bought a regulator to use with the fuel pump. I just finished buy a new fuel system and bought a jegs 110gph fuel pump. The $30 Ebay fuel pump recommened a regulator. I would for reliablity at using the 140gph fuel pump.
    boatless....
    Neat,
    One other thing you might want to check is the venting. Your tank is vented either thru the cap or the tank directly. Some one may have changed caps and put the wrong one on.
    If the fuel pump change does not correct the problem see if loosening the cap helps.
    Gooo luck
    Southwest corner AR
    One thing did you check your float level??? That has not been said! WT
    WT
    WFL Crew!!!
    Nov 2009
    El Paso, TX
    I did check the float level and it was perfect in both bowls...I didn't even think of the fuel tanks not being vented. They have the caps that are built into the hull of the boat I don't know what they're called.....are that kind usually vented? I'm assuming they should be....
    Sep 2008
    Yuma, Az
    I've never heard of that happening to a Jet Boats, but common on jet skis. I have to vent my jet skis if I let them sit for awhile. They dont build enough pressure to get fuel to the pump after a few months of sitting. I really don't see that happening to a mechanical fuel pump though. Check the basics and start with the fuel system and eliminate things as you go.
    boatless....
