can you fix a sunk place diverter pump
    Member propless dancer's Avatar
    norco, CA
    Default can you fix a sunk place diverter pump
    So this past saturday at the lake my boat took on a few to many rollers while i was pulling it off. By the time it was out of harms way, the place diverter pump was under water and now the electric motor does nothing. So I guess my question is, have any of you guys ever replaced the motors on the pumps. Is it hard, and if not could you point me where to get replacment parts.
    " Live Laterally " Dominator's Avatar
    Phoenix
    Call Place Diverter. http://www.placediverter.com/
    " NO MOTOR NO BOATER "
    " I'd rather be riding in my boat thinking about God, than in church thinking about my boat ".
    Aug 2009
    just had mine completly disassembled...not hard at all.just take your time ,check for a blown fuse first.take the solenoids off and give power from a spare battery directly to the motor to make sure its junk before you spend that cash.also look out for junk diodes... maybe try a trim switch maybe the diodes are bad and just not letting the motor get power
    Member RUFF IDLE's Avatar
    Riverside, California " Woodcrest "
    Thumbs up
    If you like to do it yourself , it's easy. I did mine 4 years ago and it still workin like a champ. If you need help or have question , just ask..
    My garage is BIGGER than my house, NO PROBLEM ! Any questions?
