impeller question 9.5
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 50
    Aug 2009
    Default impeller question 9.5
    would a 9.5 "a" impeller act like an 9.0 "AA"....im tryin to make sense of why im only seein 5100-5200 rpms with my 532/apprx 600hp at 6000
    lol 9.5 behind 600hp is yo reason nuff
    San Diego, CA
    a 9.5 "A" is a big impeller. 5100 - 5200 is not bad.
    Boat 405.
    Chico, Ca
    id say before you start cutting anything, you need to hit the button to see what kind of rpm you are getting on the juice. the bigger impeller like you have will really give you that nice holeshot like you say you have. If the juice gets you up into your power area, then you probably have the best setup the way it is. (impeller wise)
    AP
    Southwest corner AR
    X2! I had the same issue with a Hi Helix A and 725 HP 4800 RPM that was it! If I would of had a large shot no telling the RPM it would have turned! You have more than 600 HP! Hit that button and the RPM will rise and it will run like a spotted azzed ape! And it won't over rev! WT
    A mild built 532 X 1.25 =665 HP that is mild!!! A little more a 532 X 1.4 =745 HP A 600 HP 532 is a super mild build! IMO!
    1.25 and 1.4 is HP per cubic inch!
    WT
    WFL Crew!!!
    Chico, Ca
    one other thing to consider (if your setup allows) is to gradually step up....if you can start at a 75 shot or something like that...then move up as you get comfortable, you can see how the boat reacts and what kind of rpms you are turning...and add more juice as needed.
    800rpms to get the cam on peak with nitrous is gonna take at least a 200hp shot to get there i'd have a 1/2 size cut off that impellor up frt and detailed if it were mine, get the rpms closer to cam peak and small shot of nitrous to climb above peak
    Default 9.5" rocks!
    I run a 9.5" and I love it. 5500rpm on the motor = 108 mph
    I have not stayed on the NOS long enough to get a mph but its pretty fun! everybody says cut the impellor but why? my peak torque is at 5100.
    lol, not everyone runnin a 557bbf tq monster either dave
    Quote Originally Posted by OkieDave View Post
    What is it ?
    S CP
    What is it ?
    S CP
    last i herd it was a compression 557bbf
    The 9.5 " A" will act more like an "AAA" than an "AA" The old AT 9.25" "AA" acted like a "AAA". My notes from American Turbine from the mid '90's states 50 hp per 150 rpm:
    5,100 = 600 hp
    5,400 = 700 hp
    5,700 = 800 hp
    from the other posts I read, you have a Nos system? How big of a shot is it?
    Look at this chart and drawl another line for a "AAA" it should be close to the hp curve you're looking at:
    Edit:
    I'm going to suggest that if you run Nos you can do an over-lay graph like this assuming you've dyno'ed the engine to determine the rpm on the Nos. Here's how I've been doing it since '93 -'95 it's always worked for me.
    S CP
    got any idea what hp it takes to turn a basic amt ss aa-cut to 7800-8200?
    I haven't a clue.
    S CP
