cheap extra insurance
Results 1 to 14 of 31
    Feb 2010
    Default cheap extra insurance
    or just peice of mind but looky what im going to be attempting in the near future
ID:	80622   Click image for larger version.
    1977 Charger 17Foot. jacuzzi golden eagle
    402 BBC tunnel ram with dual 660 fuel leaks on the top.
    Senior Member lbhsbz's Avatar
    Long Beach
    Quote Originally Posted by skippers WFOT View Post
    It'll be hard to shoot the ball straight with them bendy sticks
    Senior Member Futs's Avatar
    Orange CA, Big River
    No, hes going to try and float the pool table so he can play pool on the water.
    Kingman/Golden Vly, Az
    OK....i give up????
    FastRat
    Colfax, Ca
    I have the same thing in my boat. Wish I would have had them five years ago
    I don't feel tardy Hallett Dave's Avatar
    Lancaster
    Talk about low freeboard. just sayin
    Im non induced and My turd leaves pretty hard as she sits.
    Feb 2010
    where i got the idea from Tim. just getting to the point of tinkering with it now after my surgery 1.5 months ago
    Feb 2010
    and floating the pool table thats some funny shit. although it does weigh less than the boat soooo???????
    The Right Coast/SE-PA
    Question
    Hmmm, if you be thinking that will do you for flotation > you bess be adding a whooooole lot more.
    Or, you just have a fetish for water noodles
    Feb 2010
    thats just a start. i think i need about 10 more. each noodle is rated for about 100lbs of bouyancy asistance. it wont keep it ontop of the water but it could HELP keep it from the bottom
    Senior Member miketeast's Avatar
    maryland
    it will either float or it will sink all the way to the bottom.
    100 lbs...not a chance...
    at 14.5"diameter x 30length"
    these are rated for 125lbs FULLY INFLATED to 2psi
    http://www.lfsmarineoutdoor.com/scri...?idproduct=134
    only thing i worry about is it being 'just too small' where the current will take your boat underwater to who knows where...i use 4 in my sbc cheyenne
    Team FTL
    Horsepower Homo
    Centistoke Fag
    Southwest corner AR
    Skipper this is what I had planed to do also! I have also been told big bags of packing peanuts! But if the bag gives up it will be a big mess! WT
    Or even Mae West Vest! many!!!
    WT
    WFL Crew!!!
    Feb 2010
    i found a link from a asked queston about pool noodle buoyancy. here was a reply.........I'm sure you realize that your 3.5" diameter, standard length pool noodle is not really "floating" 200 lbs, though. Your body in the water is displacing most of your 200lbs of weight and the pool noodle has enough buoyancy to keep the rest of you afloat.
    Its not too hard to figure out how much weight a piece of pool noodle will really support. Remember, something floats because it actually displaces more water weight than it actually weighs. This is why a heavy metal ship floats.
    I hope that I don't lose the math challenged here [] !
    I'm going to use the metric system since the weight of water per volume is easy: 1 Liter or 1000cc (or ml) equals 1 kg or about 2.2 lbs. We're going to use 1 foot of showtime's 3.5" diameter noodle. Converting this to metric we use 1"=2.54cm. So, the noodle is 30.48cm long by 8.89cm in diameter.
    Here goes: volume of a cylinder=pi(r)(r)(length)or 22/7 X 4.445cm X 4.445cm X 30.48cm = 1892.7cc or 1.89L
    Converting the weight of 1.89L of water back to pounds is 1.89kg X 2.2=4.16 lbs. This does not take into account the hole going down the length of the noodle! In other words, the noodle will actually support a little less than 4.16 lbs!
    So.......1 foot of 3.5" diameter pool noodle should float about a 4lb piece of metal on top of the noodle.
    Remember, if your boat is "sunk" it is displacing water so the pool noodles don't really have to support the entire weight of your boat. In other words, if your boat weighs 15 lbs, you don't really need 15 lbs of buoyancy although it certainly won't hurt if you can fit it all [] .
    so with this calc, if there is2000lbs of boat then you need 62 noodles for great floatation. I gues ill just keep gathering. but i still think something is better than nothing. and my bulkhead is still seald and that alone will keep the nose in the air
    Colfax, Ca
    Better than nothing!!!!!!!!!!!!!!!!!!!!!!!!!!!
