starter issues
Results 1 to 14 of 15
starter issues
    Jul 2009
    Default starter issues
    OK im stumped. My starter works when it wants to. The solenoid is good. All connections are tight. what could it be? the starter is fairly new.
    WFL Crew TINTDESIGNZ's Avatar
    East Texas
    I feel yo pain!
    WFL CREW!
    http://www.performanceboats.com/cont...-magazine.html
    Everybody wants some...I want some too!
    Jul 2009
    It looks pretty sketchy when i have to load start the starter just to take off..
    I don't feel tardy Hallett Dave's Avatar
    Lancaster
    Quote Originally Posted by 93ultra View Post
    Ignition switch perhaps?
    Im non induced and My turd leaves pretty hard as she sits.
    Jul 2009
    just replaced that last year.
    Lancaster
    But are ground connections adequate.
    Senior Member GRoper's Avatar
    How old is the starter? is it a bottom mount? If it gets wet, which is usually the case with jet boats, there is no telling how long they will last. Ive had em go out in a season from water. is it just spinning and not enguaging? if so try taking it off and greasing the gear shaft that comes out of the starter, if it just clicks it could be your battery isnt charged up enough. starter grimlins can be frustrating.
    Jul 2009
    just checked with ohm meter, when the key is in on, i have 12.8 volts. At cranked 0.03 output of the ignition switch.
    Please describe "works when it wants to" is this hot ,cold , anytime ?clicks , clunks nothing at all when this happens what do the guages do ? does the boat have an "Aux" solenoid besides the actual starter solenoid (helper) do you have a full 12volts at the solenoid on cranking often times theres an enormous voltage drop from Battery to dash and back and then to the solenoid ? Tom
    Nov 2009
    Langley, B.C. Canada
    well if you are only getting .03 volts from the ing switch on the start circuit there is a bad connection some where. when you say checked with an ohm meter that really doesn't tell you any thing if you take a battery cable and snip it in to and push the two ends together you will see no restriction but if you push 200+ amps across it you will loose a lot of voltage. just start either jumping out parts of the circuit or volt drop test it and good luck
    Aug 2009
    [/IMG]argh...i just got through this with the help of the people on this site)first,good battery?13+ volts. 2nd 10 ga wire to and from key switch( to help eliminate voltage drop) 3rd set up a helper solenoid .4th verify good starter at auto parts store. 5th take out spark plugs and spin it over without compression(no water in the cylinders)
    Jul 2009
    Works when it wants to= cold, hot, first start, last start, midday, its a guessing game.
    I do not have a helper solenoid.
    The starter doesnt engage when it does this.
    I have 2 fully charged batteries. When im hooked up to the battery charger it will work fine( maybe this has something to do with it??
    Could it be a wire issue?
    Mike, thanks for the diagram, its funny because i was talking to someone yesterday about this and he said he saw one on here some time ago pencil whipped.. Perfect timing!
    Lancaster
    This should tell you something Grasshopper.
    Aug 2009
    mine was the same...a ford style sol is 10 bucks some battery cable is another 10 plus an hour of your time...it sounds like theres not enough voltage to fire the sol...the helper sol turns 30 feet of wire into 1 foot...mikey
