drive line any ideas
Results 1 to 10 of 10
    Senior Member bigblock68's Avatar
    Default drive line any ideas
    i have a tx20 war hawk trying to set motor today i have oil pan about 1/8 inch from intake and still have to much angle motor is set at 4 degrees as same as intake and idea thanks
    Senior Member bc18's Avatar
    Quote Originally Posted by bigblock68 View Post
    what is the depth of your pan?
    It's a sickness Eliminator#1's Avatar
    QC, Mcintyre
    you might need to move the motor forward and make a new drive line, it dont look like the motor was aligned right in the first place or @ all, there are a few guys with tx20's on here maybe one will chim in.
    LIFE'S GOOOOOOOOD!!!!!!!!!!
    QE 072
    the motor is just setting there boat never been rigged for motor oil pan is just factory truck pan its just a motor to get on the watter this year. Only way i see to help it my self is moving the motor forward having a center drive line built
    i thank it has a low pro aggessor intake in it could this be why the pump shaft is lower
    ......oil pan is just factory truck pan .......
    The problem is the truck pan. It is roughly 1" deeper than the car pan. The jetboat-specific pans are all about 7 7/8" at the rear of the sump, which is the same as a car pan.
    Shell Knob, MO
    You need to put a Jet Boat Oil Pan on the motor and the problem will be solved.
    Duane HTP
    Aug 2009
    i say all of the above is your prob.1 truck pan=bad idea(you need oil control in a jet boat or youll prolly lose your motor ie, baffels ,trap doors ,windage tray depth of pan 2. lo pro definatly lowers the engine height compared to stadard intake 3. a longer driveline lessens the angle but changes the center o gravity and therefore changes the way the boat handles maybe good maybe bad prolly bad and omg slower
    looks like a oil pan will let me lower another 1/2 inch or maybe a hair more my pump is set back 4 inches dont thank that will make a dif
    we are batteling the same problem as you except our drive line is exactly 0* we have a low profile intake as well. we just pushed the motor fowards right in front of the intake for now until this winter when we will modify the pan in the rear. instead of the rounded edge in the back we are going to make it angles up to clear the bolts. does that make sense?
