pump question
Results 1 to 14 of 17
pump question
    The Brown Bomber oldmudwiser's Avatar
    Apr 2010
    apple valley ca
    Default pump question
    12jb-a.. ok im running a little less than 500 hp and it stops at 4100.just wondering i need a diffent impeller?
    Sounds like your down on power a bit assuming its an A impeller , I'd be looking at tune up etc , just curious what altitude ? Tom
    Morgan Hill
    Quote Originally Posted by oldmudwiser View Post
    1. Have you verified the tach.
    2. Like Tom stated, if at altitude you may not be makin' the 500 HP.
    3. Has it ever run a higher RPM?, If so check for the rope around the pump shaft scenario
    GT
    Shell Knob, MO
    Is your 500 HP from a guess or is it from a dyno sheet? If from dyno sheet, what rpm did it make the 500 HP at? 4100 on an "A" impeller would be about 250 HP. 4100 on an "AA" impeller would be about 300 HP.
    Apr 2010
    apple valley ca
    the less than 500hp is just a gess from the guy who did the machineing.
    im about at 3500 ft. so i gess i my hp is more like 450.
    429 bbf
    60 over
    460 heads
    almost 11 1/2 to 1 com
    big cam
    holley 750 vac secondary..im working on this one trying to get a dubble pumper.
    Apr 2010
    apple valley ca
    its been running for a few months and its allways ran 4100. and i did suck the rope up one time but i cut it out.
    The alitude isn't helping and theres a good possibility theres still rope in the exit side (back side of the Impeller Tom
    see what your timing is at and depending on the motor you may be able to run a bit more than a sea level "tune"
    Bullhead City, AZ
    If you have a stock A impeller in that pump with the engine you have and 36* total timing it should turn at least 4600rpms. In most cases I see 4800rpms.
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Morgan Hill
    429 bbf
    60 over
    460 heads
    Too Big of big cam
    Just sayin' you ran out of torque to accelerate any more.....Just a guess.
    GT
    Sep 2008
    OC, CA
    If your going to upgrad to a DP, get at least an 850. Built up 429/460's like a lot of carb.
    Green Bay Wi,USA
    Talk to Lakes Only, The ford timing chain may have built in retard that was an emissions fix back in the 70's. this drops the power big time. Are you running headers?
    valley springs, ca
    lakes only did some heads for me. way awsome guy and knows his fords. highly recomended
    Apr 2010
    apple valley ca
    thank u guys. my mom just pasted on monday so im done with the boat for a while.
    my condolences, sorry for your loss.
