idling temp
Results 1 to 14 of 17
idling temp
    Douglas, MA
    Default idling temp
    I seem to be at about 160* and 10lbs of pressure at cruising speed...sound about right?
    I think hammered down I am still getting about 20lbs of pressure, so I think I am going to have to re work some of the lines.
    Nov 2008
    Fuquay-Varina, NC
    I cruise at about 120* and idle at 160*
    '77 Caribbean
    Douglas, MA
    Quote Originally Posted by Storz View Post
    it seems to drop some at cruise...160 just seems awful hot at idle.
    southwindsforsure justsquirtin's Avatar
    Jul 2009
    rio linda calif
    are you running a thermostat setup or valving it off
    Douglas, MA
    Quote Originally Posted by justsquirtin View Post
    pump to a T...pressure relief on one end...ball valve all the way open and then into the logs.
    Jul 2009
    rio linda calif
    im runnin a thermostat setup with otheaders and im idling 160 and running wot about the same-sometimes it will idle about 175 depending how hard ive been running=dont know if this will help as you have a different setup
    460bbf
    Strap on the JATO konajet74's Avatar
    Antioch,Ca
    160-180 all the time....Thermostat setup
    Nov 2008
    Fuquay-Varina, NC
    It cools right back off as soon as I give it any gas, been like that since new
    '77 Caribbean
    TJS
    TJS is offline
    CT
    170-180 all the time. Cooler in the fall when the lake temp drops a little. No worries.
    no need 2 fake it. 84Condor's Avatar
    Yuma, Arizona, United States
    i agree... mine idles around 160 no matter how long i idle in marina waiting for my truck parker.... haha. but as soon as i get on the channel and get after it a little it drops
    "i'm into snatchin' kisses... and vice-versa!" haha
    Douglas, MA
    so 160 is nothing to be worried about...good to know!
    Nov 2008
    Fuquay-Varina, NC
    Def not, think about how hot a car engine runs all the time, and its under a big giant heat trapping hood. Boat engines run nice and cool
    '77 Caribbean
    Douglas, MA
    I figure the car engine has coolant to keep the water from boiling though. I get a bit nervous when I see steam coming out of the hull
    Nov 2008
    Fuquay-Varina, NC
    Lake water is generally pretty cool though, and you're not recycling it like in a closed loop car system, your boat will constantly get a fresh wash of nice cool lake water
    If its steaming though you may want to open the valves up a bit more, to allow a little more water through the system, then again if 160 is all you ever see I would just leave it as is.
    '77 Caribbean
