hand hole cover?
Results 1 to 9 of 9
hand hole cover?
    Maple Ridge B.C. Canada
    Default hand hole cover?
    buddies broke on the weekend.any idea's why? any shops out there that would have a used one (berk jc ) thanks
    Anaheim Hills
    Quote Originally Posted by rogerroost View Post
    Could be that you flux capacitor wasn't balanced right. Happens all the time.
    Tom @ Jet Boat Performance most likely has what you/your buddy needs.
    (805) 466-4719
    i have a meirsch hand hole cover on mine. i like it. pretty stout units that fill the hole in the intake a little better. duane sells them i think, but i got mine direct
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    3/8" plate on top of the OG HH cover is pretty damn close to fool proof fix!
    Likely was he was "flyin" the boat jet takes a gulp of air and when it recharges it can shockload the cover (sometimes will even break suctions sometimes this is actually worse on "E" pumps , surprized he didn't sink it) Tom
    BTW tell him to check (maybe upgrade) to hold down bolts too they tend to streatch and can break as well
    Kingman/Golden Vly, Az
    Quote Originally Posted by TRG View Post
    10-4 on that...dont forget the gasket!
    FastRat
    Norco
    That is what happend to my Southwind. She went down.
    I made a 3/8 steel plate to go over it.
    Quote Originally Posted by danhercules View Post
    a blown HH cover on a non set back will sink like a "hot rock" Been there done that !
    also folks check your Berk retainer bolts regularly , upgrade whe you can too !
    Pro Gas Jet RedPearl's Avatar
    Ausitn, TX
    we use this hand hole cover, works great !!!!
    Don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic!
