Quadrajet Metering Rods
Results 1 to 9 of 9
    AAARRRRRGGGGGGG!!!!! Motomatt68's Avatar
    Nov 2009
    Default Quadrajet Metering Rods
    I am going to adjust my quadrajet for altitude. I was going to just change the secondary metering rods but was wondering if I should change the primary's also?
    I assume that it is running on the secondarys most of the time but will the primarys have a big effect when the secondarys are open? Do they have to be changed? I dont know why I wouldn't change them besides more work and a little more cash.
    Matt.
    Kingman/Golden Vly, Az
    Quote Originally Posted by Motomatt68 View Post
    Matt.
    do yourself a favor & get rid of the Quadrajet & put either a Edelbrock or Holley on it...much less headaches!!! ...what kind of boat & motor?...whats it used for?...where do you live?
    FastRat
    Olympia, Washington
    Nothing wrong with a q-jet, put larger jets up front and smaller metering rods in the rear and forget about it. I'm assuming this is a mostly stock application.
    Quote Originally Posted by Oldelmn8tr View Post
    i'll bet you dont run a Quadrajet??????
    FastRat
    Nov 2009
    I think Q-jets are great. This is the first marine application that I have used but for 4 wheeling they are the next best thing to EFI. I am planning on going with EFI but for now I wanted to get it running better for my vacation.
    The engine is a Volvo 260a (chevy 350) that was set up at about 1200'. It works ok here at 4500' but when I take it to 6000' and above it is a dog. It is hard to pull a skier out of the water.
    Everything is stock. I am also going to get a new engine with more power to go with my EFI but I have not found the right one yet. I am looking for something under $3200. Hopefully under $3000.
    Motorworks has a 406 with 450torque and 405hp for 3200. That would be nice and a hell of a lot more power than I have now.
    I am also considering just putting a cam in the Volvo with EFI and making do for a while.
    Decisions, decisions, decisions.
    Matt.
    Jul 2010
    Michigan
    Default LEAN the Mixture
    Please re-read what you said. He is going higher in altitude where the air is thinner. That means the carburetor needs smaller primary jets and larger secondary rods to lean out the mixture. The reason it is such a dog is because the mixture is too rich for 6,000 feet.
    In other words he needs to do the opposite of what you suggested.
    Yes, I do run a Q-jet on my boat. I also owned a performance auto clinic and have tuned more carburetors than I can count. If you need help finding jets and rods you can PM me. I still have many sizes left over.
    Morgan Hill
    How much altitude?
    Quadrajets are great carbs if you don't want to be adjusting on it forever...
    For Tahoe (6200 ft) we normally drop 1 jet size and go up on both metering rods, we also bump the timing about 2 degrees...It runs OK, but definitely not a barnstormer (whatever that means)...
    GT
    Olympia, Washington
    Sorry about that wette vette, was thinkin bass akwards. You are correct, but I still say the q jet is a great carb.
    Nov 2009
    My secondary rods have a CJ stamped on them and my primary rods has something so small that I cant read it. My wife thinks it says 4CE. It looks like that to me but I thought that the primary rods would have a number on them.
    Anyway I need to lean it up for the altitude. What should I use?
    Thanks, Matt.
