Oil Pan
Results 1 to 9 of 9
Oil Pan
    Retired Air Force Master Sergeant's Avatar
    Lake Havasu
    Default Oil Pan
    Ordered a milidon marine oil pan but it is very heavy (16 pounds). I am thinking of changing it out for an aluminum street/strip one as I can't find an aluminum marine pan. Will an automotive street/strip pan work just as good as a marine pan in a boat?
    Shell Knob, MO
    It will if it's not too deep. Your limit is about 7 1/2 to 7 5/8" deep.
    Duane HTP
    Kingman/Golden Vly, Az
    Quote Originally Posted by Master Sergeant View Post
    i run a Milodon BBC alum dragster pan, 10qt, flat bottom in my boat with a Mellings HV pump & p/u...havent had a problem with it ...just my .02 cents
    FastRat
    Senior Member crzyjay74's Avatar
    Dec 2009
    Beaumont Ca.
    Wanna sell the Milidon cheap
    Q.C./Big River
    Order an Armando's pan. You wont be dissappointed!
    Santa Clarita
    X2
    Shell Knob, MO
    X3
    Duane HTP
    Aug 2009
    x4 but, i put an armondos pan on this year very nice people and a great functioning pan.it has two sets of trap doors,a built in windage tray and solid and constant50-55 psi ALL the time, but mine showed up with out a hole in the windage tray for the dipstick.a bit of an inconvienance, i didnt figure this out until the engine was back in the boat...argh,double argh...ill remove and fix over winter.anyway buy a jet boat pan for a jet boat! oil control is very important ...mike
    Senior Member CK7684's Avatar
    Minnesota
    Is ordering a new pan worth the saving in weight? Is there really much difference? There are multiple threads on oil pans and different problems people have run into...
    Long story short tho, I've got a Stef's custom made pan and with a stock Melling oil pump (not HV) I have around 75 psi everywhere but a hot idle...
    I did need to drill a small hole on some internal bracing after recieving this pan just to allow the oil to drain back for oil changes. The design of the trapdoors was very unconventional and this created a small area that trapped oil. Very small oversight on Stef's part and easily remedied...awesome awesome pan tho
