Gettin ready to pick a Impeller...
Results 1 to 14 of 17
    the padawan
    Jul 2010
    Anaheim
    Default Gettin ready to pick a Impeller...
    So I am finally at the point where its time to pick my impeller, I have one of the berkely extreme loaders but have no idea what impeller to use, I have the bowl stuffer and the pump is being rebuilt all at the same time. My engine is a 468 BBC making 604hp/595tq and 790hp/780tq on the bottle, the rig is a 18 foot roger.
    I would like the boat to be able to hit 90+ and I think I have the power to pull the big impellers now.
    sorry if I sound like a newb... the fact is I am and this is my first jet boat, I just have been building NHRA door bangers for over 8 years and decided one of my motors would be bitchin in a boat.
    El Cajon , Ca
    You have obviousley dynoed your motor , at what RPM did you make peak HP and Torque?
    Sep 2008
    Yuma, Az
    see below
    boatless....
    Sep 2008
    Yuma, Az
    chart
    boatless....
    El Cajon , Ca
    Or
    Quote Originally Posted by Marcsrollin View Post
    x2 if its peaking above 6300 id run a b-cut
    Angier, NC
    start big then cut down
    HOT ROD BOATS
    ANGIER, NC
    pump & parts
    fiberglass work
    s.s. hard lines custom made
    pretty much anything
    the padawan
    Jul 2010
    Anaheim
    I peak just before 6000.... so from the charts I should be at a B cut?
    second stupid quesiton, will I know I am running the wrong impeller and how will I know? Engine goes into over rev?
    if peak is at 6k i'd try a a-cut and see where it rpms on the bottle
    Senior Member Futs's Avatar
    Orange CA, Big River
    Do you want to set it up for the bottle or just the motor? I set mine up for the motor at peak and let the bottle just spin it more.
    the padawan
    Jul 2010
    Anaheim
    yah I would like it on the motor, and the bottle is just extra...
    I would start with an A/B and tune it accordingly.
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Hey Tim, How many RPM do you spin your Imp. on and off the nitrous? been meaning to ask you for some time now.
    Quote Originally Posted by Bangingears View Post
    At what rpm were your peak trq numbers ?
    If you are going to rev it at or near peak hp rpm off the nos, how big of a nitrous system do you plan on running and do you have the valvetrain hardware to handle it. If you are going to be running off the bottle at 6,000 and then hit it with 200 hp you're going to be in a serious over-rev situation. Can your cam and valve train handle that ?
    I'd start with an "A" and see what it does from there. on and off the bottle
    You can have an impeller trimmed allot cheaper than adding to one.
    How big of a shot are you talking about ?
    G-
