Which BBC Header gaskets should I use?
Results 1 to 14 of 15
    Jan 2010
    Midland, TX
    Default Which BBC Header gaskets should I use?
    Putting on my Rewarder headers tomorrow, just want to do it right the first time........ lol!
    the padawan
    Jul 2010
    Anaheim
    never had a problem with fel-pros
    Senior Member lbhsbz's Avatar
    Long Beach
    I would just use hi temp silicone, no gaskets.
    Denton, TX
    Quote Originally Posted by cvcook View Post
    LBHSBZ
    talked me into trying hi temp stuff. I have not had a problem yet.
    Douglas, MA
    twin turbo's on my exhaust and never a leak. (knock on wood)
    Senior Member CP598's Avatar
    Sep 2008
    Default Victor Nitroseal
    I have been using the same set of Victor Reinz Nitroseal Graphite gaskets for about 7 years. Works great, no leaks etc. These gaskets have been on and off dozens of times, holding up real well.
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    If im not mistaken, you said Rewarders......first of all, grab a long block with some 80 grit then some 220 and clean up the flanges!
    Rewarders have to be the worst at having flat flanges, the laybacks are even more horrendous!
    With mine (Laybacks), even blocking the flanges, I still use "The Right Stuff" its a black ultra high temp sillycone, its worked so far and does not remove aluminum from the mounting surface if I need to remove the headers! lol
    I was told this method by an old (er) engine builder over in the vdrive section, he said he has not bought a set of gaskets for his deal in some time!
    He goes by the name Rick James bitch, or something along those lines.
    At least you dont have to worry about the gasket impeding the flow of exhaust!
    Im sure I will catch some hell from this, but its ok, ive gotten out of deeper piles!
    I've got blower headers on my boat. [large port] I burnt many header gaskets out. Then i got COPPER gaskets. no more leaks,and you don't have a messy bead of silicone around the flanges. IMHO
    I've been using the high temp silicone for 20+ years. Works every trime. Why spend the money for gaskets when you can get a whole tube of " gaskets" for six bucks. Plus silicone is a little more forgiving when you don't have perfectly straight or quality header flanges. Keep the bead close to the port opening and not to big, very little will squish out if your carefull.
    Senior Member CK7684's Avatar
    Minnesota
    Copper!!
    Senior Member lv4jetboats's Avatar
    fernley nevada
    Copper
    Member 78hallett's Avatar
    Jul 2012
    Norcal
    When using the RTV is it best to put it on the manifold, or the header?
    Aug 2010
    nothing but RTV here, i let it skin first before putting it together otherwise it all just oozes out. i put it around the exhaust ports on the head then get the bolts started without it touching and then once i have 2 in ill tighten em up and clamp it together.
    I am running copper.....rtv may work fine....but isnt that chit a pia to clean off every time you pull your headers??....I will pass even if was free. Just my .0000002
