71 Weiman
Results 1 to 13 of 13
71 Weiman
    Jul 2010
    Orcutt CA
    Great Classic Congratulations ! Just had a similar very original "sister boat" sold it to some nice folks who collect them Tom
    I sold mine (Weiman) to some down line relatives or Weiman they have 3 others (boats) if you PM me I'll try to put you in touch with them Tom
    Senior Member lbhsbz's Avatar
    Long Beach
    Since you don't know any history on that pump and it's been sitting, I would, at the very least, change the thrust bearing. They like to let go and do some serious damage. The bearings are cheap compared to the damage it causes if it fails.
    Glendale Arizona
    Quote Originally Posted by mattjensen View Post
    Could someone explain to me what that shim does?
    You mean the piece between the bowl and nozzle?
    If so, it's a wedge (looks a 1 or possibly 2 degree). It's used as a tuning tool for the boat's ride. Helps to get the bow out of the water some by changing the angle of the nozzle.
    The boat is cleaning up real nice.
    Man alive!! That boat sure did clean up purdy. Nice to see others that care.
    Anaheim/BHC- the Shack
    Very cool find. Something to keep in mind...... you don't want to go REAL fast in that hull or get out of it at speed. With a deep entry bow it'll try to pitch you.
    Have fun with it!
    oldsmopile equipped
    Lake Lansing MI.
    motor looks good, what kind of hp/torque are you looking to get out of it? with a olds its critical to get the oil back to the pan, have you done any oil mods? there is plenty of info here and on www.realoldspower.com a easy way is to drill and tap some 3/8" holes in the back of the heads back down to the pan, I used some clear hose so I can see it and it starts to flow around 1500 rpm. also oil restrictors, I don't like the set that most shops sell that just hammer in, I got mine from andy at olds performance products, they thread in. there are a bunch of things you can do to help the oiling system, there is an old hot boat article written by timinator, here on the boards with a bunch of good info, if you can find it its a very good read!
    good luck and nice boat.
    The Good mrjoshua's Avatar
    Aug 2010
    Albuquerque NM
    Timm's article is called "the practical olds" if you google it it comes up as a pdf. Tons of great info about building a "jet boat" 455 olds. I'm going to have him build one for me after the new year.
    Young Junior Member
    Sep 2009
    BBL
    Nice to know someones fixin up my grandpas old jetboat.. Goodtimes.
    Senior Member GA Jet's Avatar
    May 2010
    haha I see you got your daughter helping you! Thats how I started loving to work on cars. I used to hold the light and turn some bolts for my dad and thats how I learned almost everything I know.
    Now look at me! I can hold a light as steady as a stand and turn bolts like a top!
