Getting more stern lift
Results 1 to 13 of 13
    Nov 2008
    Fuquay-Varina, NC
    Default Getting more stern lift
    My boat plows, would a droop help get the tail out of the water? Right now with the diverter handle about 2-3 clicks down from teh top the boat feels the best, but is still riding really wet.
    '77 Caribbean
    Southwest corner AR
    There are a few things that would help! But first have you checked the bottom for hook with a stright edge? WT
    WT
    WFL Crew!!!
    Nov 2008
    Fuquay-Varina, NC
    Nope, how would I go about doing this?
    '77 Caribbean
    Southwest corner AR
    Need like a yard rule or a stright piece of something about 3-5' long! Get under boat and go from transom towards front in a stright line and see if you can see light between bottom of boat and stright edge. Some will be in most older boats but not a whole lot! Check this first just so you know. Hook causes a kind of suction and will hold the boat down!
    And some boats that are vbottom are a heavy layup and it is hard to lift anyway.
    WT
    WFL Crew!!!
    Southwest corner AR
    What type of loader do you have? Rideplate and shoe? Stright nozzle?
    WT
    WFL Crew!!!
    Nov 2008
    Fuquay-Varina, NC
    no shoe or ride plate, Jacuzzi WJ pump (worn out I might add) manual place diverter, straight nozzle, 1000lbs hull , stock rock grate, oh and I carry 25 gallons up front - lots working against me, but I figure a droop maybe able to help lift the boat up a bit.
    '77 Caribbean
    Senior Member splatter's Avatar
    Sep 2009
    The NC
    Quote Originally Posted by Storz View Post
    Damn, I was going to offer to let you try my droop, till you said Cuzzi.
    Salem,Or
    I have put a droop on my 21ft tahiti and shes heavy in the ass and it has
    made the biggest diffrence in the world, last summer i put the place divertor on and it just wasnt quite enough and then put a dominator bowl and droop on this summer Now it gives me enough stern lift to keep the front end from porposing
    Nov 2008
    Fuquay-Varina, NC
    Quote Originally Posted by splatter View Post
    PM Sent
    '77 Caribbean
    Dont mess with the bottom!!!!! You are opening a can of worms buddy. Find a set uf saddle tanks and loose the bow tank! That is holding you waaay back. You can try a droop BUT every boat(v bottom) I did a droop on, it planted the azz down. You could try a snoot from HTP and a few wedges.
    G H E T T O F O E L I F E
    A shoe would help you alot. Do you plan on keeping the boat?
    Nov 2008
    Fuquay-Varina, NC
    Yeah I'll keep it forever, been in the family since brand new in '77
    I also don't plan to do anything with the bottom either, really its just a family boat that looks sorta cool, I konw it'll never be fast. Figured a droop or something similar is an easy bolt-on upgrade that might help a bit.
    '77 Caribbean
    Sep 2009
    The NC
    I know you live a ways away, but you can try my droop if you want. PM me and let me know.
