diverter handle (modification)?
Results 1 to 12 of 12
    Default diverter handle (modification)?
    Getting a manual handle today and was wondering if anyone has ever shortened the handle. I imagine it makes it a little more difficult to move. The reason I ask is that the only good place to put it in my boat would be directly under my right knee. Or just to the inside of it.
    Senior Member 91foxbody's Avatar
    Stanwood, WA
    call place diverter. they actually sell a smaller handle! and it is a great mod!
    Quote Originally Posted by sandeggo View Post
    The handle is "cast" and doesn't lend well to welding as I recall you will also reduce the mechanical advantage a bit as well Tom
    Quote Originally Posted by 91foxbody View Post
    Thanks for the heads up, when I pick it up this afternoon I'll see how easy it would be to modify. I can cut it down and weld it if I have to. The reason it can't go further left (inbetween legs) is my subfloor meets the bottom of the boat.
    Tom, I know a few tricks for welding cast aluminum.
    Kingman/Golden Vly, Az
    if you have bucket seats, put it rite next to the side of the seat...works fine there! ...your not moveing it all the time!...just sayin'
    FastRat
    FastRat
    my boat is tiny inside and that space is REALLY limited.
    Member Trever Leach's Avatar
    Jun 2010
    thousand palms, Ca
    my boat has it in between the seats. there is not much room in my boat at all. when I get home I will send you some pics on your phone and see what you think.
    and it works great right there. I didn't like it between my legs
    Stanwood, WA
    ive had it between my legs and on the floor next to me. its a toss up which one i like better. i think id like hydralic better and keep the control on the steering wheel best though.
    Feb 2010
    mount it on top of the dash in front of the wheel.
    1977 Charger 17Foot. jacuzzi golden eagle
    402 BBC tunnel ram with dual 660 fuel leaks on the top.
    I picked it up, I'll figure something out
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Quote Originally Posted by skippers WFOT View Post
    Then what in tarnation is he gonna do with the gages then????
    I'm gonna have to hang a red tag on this sumbitch when I tow. I think to the right of my right knee is gonna have to work. Where should I tap the transom housing for the bulkhead fitting? It's one of the rubber sealed conduit fitting deals.
