Let's see your dashes
Results 1 to 14 of 35
    Las Vegas, Nv
    Default Let's see your dashes
    I ordered and recieved my autometer marine gauges, but My Tac has been on back order for almost two months now and it is frustrating as hell!
    I baught a speedo with the setup, but I am torn between running the speedo and tac or just the tac. The layout that I have been leaning to is the tac and speedo in the center and two smaller gauges to each side, or should I just run the tac in the center and and two to either side? I am just looking for the cleanest look on an 18- 19 ft boat.
    So let me see your layouts I am especially intrested to se set ups with a speedo and tac in the mix....Hal
    Senior Member INTHERED's Avatar
    Apr 2010
    Rancho Cucamonga
    Here is what I did with mine. Has a full pack of gauges. Didn't have room for the boost gauge so I put it in a pod on top...
    bad photo but u get the idea.
    from left 2 right.
    Hrs, volts, oil psi, rpm, mph, water temp, fuel.
    spokane, WA
    Tach, Oil pressure, Water temp, Fuel pressure, Vac/Boost
    Puting a gps on the left hand side of the wheel
    I like my women like I like my boats......Fast and ready to get wet at all times!!
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
ID:	81151   Click image for larger version.
ID:	81152   Click image for larger version.
ID:	81153   Click image for larger version.
    Loose, the Dogs of War!
    Member McIntyreBahner's Avatar
    Apr 2010
    Norco,ca.
    Default dash
    tach, water, oil, volts, and radio.
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    its older but still the same,.... temp, tach, oil press
    Senior Member harley222's Avatar
    Sep 2009
    here is mine...
    Chico, Ca
    this is my sanger mini cruiser setup as it was with the last engine.
    crappy pic of the gauges but you get the idea.
    and now with the new boosted engine i've added....well.....a few more gauges. the key hole has been made to a new gauge hole, and 3 more holes extending out past the original ones. I'll post a pic when i get one of the new holes.
    Andrew
    Senior Member 91foxbody's Avatar
    Stanwood, WA
    Quote Originally Posted by TwinTurbo540 View Post
    just how travis has his gauges here, is how mine are configured.
    and personally i only like them this way. simple and not too many but yet all you need.
    Mar 2010
    Clarksville, TN
    Heres a pic of mine
Name:	New Guages.jpg
    Heres a pic of mine
    Question
    Why have a tach that goes all the way to 10k RPM's?
    Feb 2010
    so you can hit the recall button and see how high that f***er went right before you blew the engine
    1977 Charger 17Foot. jacuzzi golden eagle
    402 BBC tunnel ram with dual 660 fuel leaks on the top.
    Mar 2010
    Clarksville, TN
    Question
    Its the only one I could get with the memory on it .. And I "think" big tach are cool in Hotrods and a jet boat is a "HOTROD" atleast mine is
    And the same reason you put a hour guage in yours. Cause you wanted too !!!!!!!!!!
