quick rideplate ?
Results 1 to 8 of 8
quick rideplate ?
    Senior Member hydroman916's Avatar
    Sep 2008
    sacramento
    Default quick rideplate ?
    19 daytona, ride plate was at 0*, basically level with the bottom of the boat, I moved it up to 4*, is this too much to start at
    get blown or get blown away
    Senior Member lbhsbz's Avatar
    Long Beach
    Quote Originally Posted by hydroman916 View Post
    not that I know $hit about $hit, but I would take baby steps. How did the boat do with the old setup?
    Take it to 2° and see what happens, if you don't get wet...then go to 4°
    PS: hit ALT 248 for the ° thing.
    Sep 2008
    sacramento
    it was ridn wet at 0*, just in front of the motor, maybe 1/4 the way back, the nozzle looks like 5-6*, so the 4 on the ride plate is pretty close to nozzle angle
    Long Beach
    Start with 2, see what it does, then go to 4 if you're comfortable with 2.
    San Diego, CA
    2 degrees up from the keel is a good place to run it. 4 is generally too much. V bottoms like 4 up, not so much on daytonas
    Boat 405.
    Long Beach
    So ... wait. I gave good advise? Hot diggity.
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    So...I guess any advice given by you will be questionable from this point fwd!
    Senior Member 2002CP19's Avatar
    Lake Arrowhead/Lost Lake
    Quote Originally Posted by TRG View Post
    Lol.
    Quote Originally Posted by schick View Post
    Hold it firmly on the ground, a few pelvic thrusts should do the trick. If not repeat till satisfied!
