Pulling the engine with a 3 point mount bellhousing
Results 1 to 3 of 3
    Aug 2009
    Missouri
    Default Pulling the engine with a 3 point mount bellhousing
    Is it best to unbolt the driveline from flywheel or just slide driveline out when removing the engine?Its a 3 point bellhousing and it looks very hard to get to the bolts on the flywheel.
    Quote Originally Posted by lakefreak View Post
    Leave the D/L on the motor pull forward and slightly "up" a the same time Tom
    Aug 2009
    Missouri
