455 olds reccomened carb!
Results 1 to 14 of 16
    Wetnreckless805 Olds 455
    Mar 2010
    Paso Robles
    Default 455 olds reccomened carb!
    Any suggestions on a carb for my olds 455....im running an edlebrock 600cfm and am not getting enough fuel to rev out all the way.
    Default 800dp/750 vac
    Quote Originally Posted by wetnreckless805 View Post
    My 455 went 54MPH with an 800DP, and 57MPH with a 750 vac sec if that helps...The conditions were the same, so I can only assume the 800 was too much for it......Mild hyd cam, alum intake, wet logs.......Ray
    LOUD BOATS SAVE LIVES
    Senior Member pilot940's Avatar
    Chandler, AZ
    I am running a holley 750 marine with vac secondaries. Works great right out of the box! I have a mild cam JM25-28 that mondellos offers, performer intake, 1.7 rockers, flat top pistons and headers. I am turning a Jacuzzi WJ with a energizer kit A impeller at 5100rpm and getting 62mph.
    Dec 2009
    Okanagan Valley B.C.
    Is your suspected lack of fuel due to the carb/jetting, or the fuel delivery system... ie: fuel pump, fuel line diameter/routing, type of filter, pickup(s) in the tank? All things to consider
    I run a Holley 750 vac. (3310), but have tried a 600 vac. Holley (1850), and 625+750 Carter's... they all ran the engine pretty close to one another... I run an AA impeller
    Kingman/Golden Vly, Az
    try a Edelbrock 750cfm on it!...might just do the trick...also...i think Ray has run a Holley spread bore 750cfm vac sec on his test boat (Olds) with good luck...just sayin' my .02 cents
    FastRat
    Member E Rock's Avatar
    Jun 2010
    Tulsa OK
    im running the stock 800 cfm quadrajet, seems to do pretty good. im gonna go through it with some info from this guy.
    http://www.cliffshighperformance.com/ lots o good info here and he also wrote a book on q-jets
    Senior Member sleekvino's Avatar
    750 dp, done..your welcome
    PORNO RACING INC WHERE ITS "HARD" TO WIN
    South west Colorado
    Wet-
    Not to step on this post but I have a Edelbrock 750 off my 455 in the spam section.
    Lake Havasu az.
    And i run a tunnel ram w/ 2 660's......runs fine enough to push my hydro to about 100mph.
    Sheriff Joe Arpaio
    Quote Originally Posted by sleekvino View Post
    Times 3 or 4
    Default Spread bore
    FastRat
    Ron, that is an 800 DP Spread bore carb, and no I haven't put gas in it since I went through it....... Still waiting to build a spread bore cable plate for under the carb.....AND, the 800 will be too much fuel for my 455 as a 4150 800DP went 54MPH, and the 750 vac sec on it now runs 57MPH........... I responded to his thread in spam about another 3310-3 750 I have here in Cal........Ray
    Shell Knob, MO
    Read your PM.
    Duane HTP
    Lake Havasu az.
    So....if i replace my 2 660's with a 750 vac sec i should be able to run faster
    than 100?
    Sheriff Joe Arpaio
    Default Well, no....
    Quote Originally Posted by Sold honda.bought hondo View Post
    than 100?
    Ah, that would heavily depend on what else is in the motor. He is running a hyd cam, and looking for "fun"....... I think my motor, and his, might be close in fuel requirements, that doesn't mean smaller is always better........... Most of the time it is though........Ray
